How to efficient use CCTV
Hello All!
I'm new in the CCTV and ZM Could someone from you recommend to me, how to setup efficient my house CCTV system? (6 Hikvision D140H cameras, SBC server (Odroid H3+, 2TB SSD (1GB for CCTV usage))).
My first thought is to setup up recording:
- constantly with 1 frames per second
- at alert/Zones 10 frames per second
What do you thing about this? Is is possible in ZoneMinder (if yes, could you please send me link to the guidance)?
Also should I use ONVIF or FFMPEG?
Any other options to save CPU load and SSD space? H.265+ is a good choice?
And last question - should I use ZM detection system or build-in camera Hikvision decection system (with signal to ZM to record)?
Re: How to efficient use CCTV
You recording scheme is quite workable.
You can find guidance in the wiki.
For a local camera network with IP cameras, use ffmpeg.
Passthrough recording is lowest cpu.
You can try h265, but I don't think it works at this time. Well, the recordings work, but browsers won't play it last I checked.
If you want live view in Montage, you'll need to save some jpegs. I use Analysis images only.
You can use an HDD for storage, cheaper than SSD. Leave the rest on the SSD.
H.265+ is bad, as the long GOPs mean ZM has to buffer a huge number of frames.
Thanks for your support! h265+ works - I mean I can view live, also recordings for me it's not a problem (I don't need to view them in the browser). I think that using 'On demand' option in Capturing and Decoding should also save some CPU - am I right?dougmccrary wrote: ↑Tue Sep 26, 2023 12:33 am You recording scheme is quite workable.
I'm also not sure how to setup camera to record in two ways
Because in ZM I can select "On Motion / Trigger" OR "Always" - could you please share with me the link to certain guidance where I can setup my camera as mentioned before?
And last question - should I use ZM detection system or build-in camera Hikvision detection system (with signal to ZM to record)?
Use h264
ONVIF is used to detect cams and save settings
Use FFMPEG
Source Method: TCP
Save jprg's disabled
Video Writer Camera Passthrough
Function Modect
You may need to adjust the zones for outdoor cams to filter out movement of trees and vegetation.
At the camera set the FPS to 5 to 10 FPS. Key frame interval double the FPS which will give a full frame every two seconds. Also use no higher than 1080P
I use a 500 GB SSD with 5 cams and seldom use more than 15% disk space My server is an i3 quad core running Debian 12.
Use FFMPEG
Source Method: TCP
Function Modect
Can't say as I don't have that camera.should I use ZM detection system or build-in camera Hikvision decection system (with signal to ZM to record)?
If I were you, I'd do both on one camera with two monitors and compare the results.
[quote=bbunge post_id=131880 time=1695766270 user_id=19500]
Use h264
Use FFMPEG
Source Method: TCP
Function Modect
[/quote]
Thanks for support, but... Where to find that 'Funcion' option....? ZM v1.37.45
Any why Modect? As I can read, it record while motion. But I would like [b]also[/b] to have constant video with 1 FPS/sec just in case of motion detection failure.
[attachment=0]Wklejony obraz.png[/attachment]
Use h264
Use FFMPEG
Source Method: TCP
Function Modect
[/quote]
- Wklejony obraz.png (72.15 KiB) Viewed 13740 times
"Function" is on the camera general tab.
3-4TB HDDs are pretty cheap now...
Me too. Mocord is continuous with detection. Frame rate is a toss-up between smooth recordings and disk space.Any why Modect? As I can read, it record while motion. But I would like also to have constant video with 1 FPS/sec just in case of motion detection failure.
As I uploaded in my previous post - please look at the screenshot - there is no "Function" option in the general tab....dougmccrary wrote: ↑Sat Sep 30, 2023 1:06 am "Function" is on the camera general tab.
I know that 3-4TB are not expensive... but I would like to avoid using additional HDD and extra CPU load due to continuous recording...
Posting in the 1.36 section running 1.37 will lead to incorrect advice.
Under Recording you can choose On motion or Always in 1.37.
Thanks, I'm asking here because I cannot find 1.37 subboard
Ok, but it will record only in one way only, so the question is open:
is it possible and how to setup camera to record in two ways at the same time:
- On motion with 10 frames per second
The major sections are general, support, development, and miscellaneous.
Scroll down to development and see 1.37 branch.
It is, great!
But can anyone answer to my ask?
Not to my knowledge, unless:
You can set a main stream on the camera at 10FPS, and the second stream at 1FPS. One stream per monitor...
