Stopping alarms when PTZ camera is moving
piflipper
Post by piflipper »
Hi All,
I've managed to get an unbadged PTZ camera working great in zoneminder and run a script, via cron, that pans the camera every half hour at night to a new location. If I run the commands from the CLI everything works as I'd hope, but when run via the script I still get alarms.
The first command to disable the camera is :
sudo zmu -m 4 -D -U "User" -P "PASSWORD"
2nd command moves the camera:
sudo zmcontrol.pl --id=4 --command=presetGoto --preset=002 "could be 001, 002 etc"
3rd command re-enables the camera:
sudo zmu -m 4 -E -U "User" -P "PASSWORD"
I have also tried to achieve the same by switching profiles, then moving then switching back still get alarms.
Can anyone help please?
BiloxiGeek
Re: Stopping alarms when PTZ camera is moving
Post by BiloxiGeek »
I've been using get_zones.pl script I found here and running:
get_zones.pl -s inactive -z <zone_name>
Get a list of zones:
get_zones.pl -r
piflipper
Post by piflipper »
Hi BiloxiGeek,
Do you have a link to that script, I can't find it anywhere on my setup?
piflipper
Post by piflipper »
SOLVED
Answering my own question here. By putting a sleep 10 command before re-enabling the camera stops the alarms happening. Gives time for the movement to complete and settle (focus etc) before monitoring resumes.
Cheers
BiloxiGeek
piflipper wrote: Tue Sep 05, 2023 10:17 am Hi BiloxiGeek,
Script is in this thread if you want to test it out, it doesn't seem to be part of ZM natively.
viewtopic.php?p=103513
