ZM upgrade 1.36.21 to 1.36.23 multiple failures
codabiz
Post by codabiz »
Was running ZM 1.36.21 on Ubuntu server 18.04.6 Bionic - all OK . Today upgraded to 1.36.23. During upgrade received warning:
>Warning The unit file, source configuration file or drop-ins ... changed on disk Run 'systemctl daemon-reload' to reload units
System pretty much broken. Random stopping of all cameras, Montage: random camera stopping and starting. Multiple errors in logs for all cameras:
1. Memory map file /dev/shm/zm.mmap.5 does not exist
2. Command 'zmc -m5' removed from pending list
3. Shared data size conflict in shared_data for monitor Flank Wall
4. Did not find a second keyframe in packet in the packet queue
5. Found locked packet when trying to free up video
6. You have set the max video packets in the queue to 20
Any ideas?
Re: ZM upgrade 1.36.21 to 1.36.23 multiple failures
Roll back, it’s borked.
Yeah sorry everyone.
Took me all night to find all the breakage. I have now released 1.36.24 and I think it's good. Packages building, just working on the announcements.
Isaac
codabiz
Re: ZM upgrade 1.36.21 to 1.36.23 multiple failures - Solved with 1.36.24
Post by codabiz »
Just upgraded to ZM 1.36.24, all looks good. Many thanks Isaac, for all your ZM work.
ZMBrian
Post by ZMBrian »
1.36.24 solved my issues also. Thanks!
rip
Post by rip »
iconnor wrote: Sat Aug 06, 2022 1:39 pm Yeah sorry everyone.
Isaac
Thank you for all the work you do. I am seeing a lot of these, however, the actual steams look ok.
8/6/22, 9:21:35 AM PDT	zmc_m3		9596	ERR	Can't open video codec!	zm_videostore.cpp	343
8/6/22, 9:20:40 AM PDT	zmc_m4		7144	ERR	Can't open video codec!	zm_videostore.cpp	343
