Good morning,
for test I installed ZM 1.36.15 on 2 setup configurations:
1. a Samsung laptop with Ubuntu 20.04
2. an Odroid XU4 board with Ubuntu 16.04
11 cameras working fine except an issue on both setup configuration.
When in montage view (browser is Firefox 100.0) the system takes too time (and sometimes hangs up) to give me the final image (all: auto, layout: 3 wide).
I don't have issue with ZM Ninja on my Iphone: I was able to connect ZM Ninja to the setup configuration 1 and working fine the montage functionality that is very fast.
It seems that the montage view functionalities takes too much resources of the system (the Odroid board and also the more powerfull Samsung laptop - that's the reason I tried with 2 configurations, the second more powerful).
I have a working fine production environment (another Odroid XU4 board, Ubuntu 16.04, ZM 1.30.4, 11 cameras) with no issues with montage view functionality.
Did anyone have such behaviour with Montage view functionality and ZM 1.36.15?
Could you suggest a solution?
thanks
ZM 1.36.15 - Issue on Montage View functionality
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
Re: ZM 1.36.15 - Issue on Montage View functionality
Solved - a Firefox misconfiguration. Restored the original configuration
Would you please specify...what?
I found a wrong data entry I did through about:config in firefox. In particular network.http.max-connections-per-server defined as Boolean False or True (I don't remeber).
Thinking to other possible misconfigurations in Firefox caused by me I resored Firefox: Help-> Issue resolution-> Firefox restore
