Hi.
Is a beginner with Zoneminder. I wonder if anyone has managed to get D-Link's camera DCS-8635LH in Zoneminder considering buying one.
Have searched online for it but failed to find anything.
Today uses D-Link DCS-8000LHV2 which works well.
Run Zoneminder v1.37.13.
Grateful for information.
D-Link DCS-8635LH
Re: D-Link DCS-8635LH
Yes, have seen that it is ONVIF.
But beginners as I am, I would love to hear if anyone has succeeded before I shop and how they have configured it.
This usually means it will work, if it's not physically broken.Support for ONVIF Profile T lets you easily record video streams to your ONVIF compliant NVR, VMS or NAS system for centralized viewing or continuous, 24/7 recording. Not only that, but you can also use an ONVIF compliant device to control your camera’s setting without using the mydlink app.
From onvif profile T spec:
I have yet to see an rtsp camera that wouldn't work with ZM.7.1.1 Device requirements
• Device shall authenticate HTTP requests using Digest authentication as described by the
Core Specification.
• Device shall authenticate RTSP requests using Digest authentication as described by the
Core Specification.
• Device shall authenticate RTSP requests tunneled over HTTP using Digest authentication
on the RTSP level as described by the Core Specification.
