Good evening,
does anybody know how to get the Axis 223M working with zoneminder?
Thanks in advance.
Kind regards
Heimo
Axis 223M
Re: Axis 223M
I was told that most Axis cameras will work. I am quite new here but manage to get a couple of M3025-VE to work with relative ease. Perhaps, if you will tell us where you got stuck. Below please find a manual for your camera. All required information might well be in there.
https://www.axis.com/files/manuals/um_2 ... n_0209.pdf
Ta.
Ta.
Re: Axis 223M
Thank you very much for your answer. I cannot find the correct settings for getting it worked with zoneminder. I have tried a lot.
regards
Heimo
regards
Heimo
Re: Axis 223M
Perhaps if you will tell what have you tried.I have tried a lot.
If I understand you correctly, you have installed Zoneminder correctly according to https://zoneminder.readthedocs.io/en/st ... index.html.
What left to be done is camera settings https://wiki.zoneminder.com/Dummies_Guide. Do follow the latter step-by-step. If you will tell which particular step you have trouble with and what are your current settings. Except you will need to replace some settings by the information from Axis 223M Users Manual https://www.axis.com/en-gb/products/axi ... umentation.
A few of the most important settings are under:
Console > YOUR_CAMERA > General > Source Type = Ffmpeg
AND
Console > YOUR_CAMERA > Source > ...
Source Path = rtsp://username:password@192.168.0.xxx/mpeg4/media.amp (I'm purely guessing here)
Capture Resolution (pixels) = 1600x1200 2MP
Ta.
Re: Axis 223M
Dear Greg,
thanks a lot, but it does not work. I have tried a lot of strings.
Kind regards.
Heimo
Kind regards.
Heimo
