live view (1.35.16)
Posted: Wed Dec 23, 2020 7:48 am
Greetings. I installed a new server, connected it, it looks like everything works, but online viewing is constantly blinking. In chrome console this message is:
while there is a picture. But the browser is constantly reloading the page.
paths to сgi-bin are correct.
if you open the link, then the picture goes constantly.
http://91.х.х.58/zm/cgi-bin/nph-zms?scale=0&mode=jpeg&maxfps=30&monitor=42&auth=aecfea....aea0&connkey=282886&rand=1608709615
js_logger-base-1607635642.js:95 getStreamCmdResponse stream error: Socket /run/zm/zms-770446s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.
Error @ js_logger-base-1607635642.js:95
checkStreamForErrors @ skins_classic_js_skin-base-1607635642.js:400
getStreamCmdResponse @ skins_classic_views_js_watch-base-1607635642.js:283
fire @ jquery.js:3187
fireWith @ jquery.js:3317
done @ jquery.js:8757
(anonymous) @ jquery.js:9123
load (async)
send @ jquery.js:9142
ajax @ jquery.js:8656
jQuery.<computed> @ jquery.js:8807
getJSON @ jquery.js:8788
streamCmdReq @ skins_classic_views_js_watch-base-1607635642.js:355
streamCmdQuery @ skins_classic_views_js_watch-base-1607635642.js:499
(anonymous) @ mootools-core.js:1
setTimeout (async)
delay @ mootools-core.js:1
initPage @ skins_classic_views_js_watch-base-1607635642.js:829
ready @ jquery.js:3536
completed @ jquery.js:3552
