I was successfully running Zoneminder 1.34.16 on Ubuntu 18.04 without any issues however I accidentally uninstalled it when running
apt purge php7.4*
Anyway, when I realized what happened I simply reinstalled it with
apt install zoneminder
- I can see no Live video stream (camera offline in each window), although cameras work and I can see video recorded.
- API does not work, When opening
myserver/zm/api/
CakePHP: the rapid development php framework
Not Found
Error: The requested address '/api/' was not found on this server.
CakePHP 2.10.8
root@nas:/# ls -l /usr/share/zoneminder/www/api
total 40
drwxr-xr-x 10 www-data www-data 4096 июн 12 21:41 app
-rw-r--r-- 1 www-data www-data 174 июн 9 19:10 build.properties
-rw-r--r-- 1 www-data www-data 10315 июн 9 19:10 build.xml
-rw-r--r-- 1 www-data www-data 837 июн 9 19:10 composer.json
-rw-r--r-- 1 www-data www-data 3252 июн 9 19:10 CONTRIBUTING.md
-rw-r--r-- 1 www-data www-data 1454 июн 9 19:10 index.php
drwxr-xr-x 3 www-data www-data 4096 июн 12 21:41 lib
-rw-r--r-- 1 www-data www-data 437 июн 9 19:10 README.md
