"Auto Stop Timeout" field on the Control tab of the Monitor Dialog only accepts integers
simonpg
Post by simonpg »
I dearly wish I could fix this myself, but I am not there yet; so here is an easy bug for someone. Version: 1.34.0-buster. If you enter a fractional value, which you are going to do, you get a fine message that says, "Please enter a valid value. The two nearest valid values are 0 and 1."
Re: "Auto Stop Timeout" field on the Control tab of the Monitor Dialog only accepts integers
So I think this value is in usecs... so 1 second would be 1000000
Not sure why we seem to be suggesting that it is in seconds, we use usleep....
simonpg
Post by simonpg »
When the script gets the value, it is 1000000 if the form is 1, so there is conversion going on... Also, the Docs indicate that the 'autostop' parameter "will be a timeout in decimal seconds, probably fractional."
