Zoneminder is freezing with Reolink RLC-511W
solid
Post by solid »
I have a camera Reolink RLC-511W connected in WiFi.
ZoneMinder is installed on a Debian (v9). Debian is a VM installed on my ESXI.
When I add the camera to ZoneMinder, either manually or via OnVIF detection, it is added without any problem.
However, after some time (quite variable), my VM freezes and ZoneMinder becomes inaccessible. I identify that the problem comes from this camera, because by removing it I do not have the problem. On ZoneMinder, I have 2 other cameras (Foscam C1) that work without problems (one in monitoring, one in modect).
Regarding my camera Reolink, the problem occurs whether it is the low-definition stream or high-definition stream. The problem is that the camera is monitoring, modect or record.
Do you have an idea of the problem ?
Best regards.
banzaay
Re: Zoneminder is freezing with Reolink RLC-511W
Post by banzaay »
I have a similar configuration with two Reolinik RLC-511W and one Foscam FI9901EP running on a real server Ubuntu 18.04 with Zoneminder 1.32.
The Reolink are just arrived and I'm testing them but now everything is working fine.
I'm using the standard configuration for the monitor, just set the resolution to 2560x1920.
Bye Mirko
pms
Post by pms »
banzaay wrote: Tue Dec 10, 2019 11:04 am I have a similar configuration ... and one Foscam FI9901EP running on a real server Ubuntu 18.04 with Zoneminder 1.32.
Hi MIrko,
Can you give me your settings for Foscam FI99901EP camera?
In my browser I get a nice picture using url:
http://192.168.2.210:88/cgi-bin/CGIProx ... mypassword
But Zoneminder never can contact the camera :(
Would like to see a working configuration.
Regards,
PMS
banzaay
Post by banzaay »
This is my configuration (sorry but is in italian):
The URL used is:
rstp://<username>:<PWD>@192.168.1.100:88/videoMain
Bye
pms
Post by pms »
Thanks!
I will test the settings although it looks like I already tried these RSTP:// link as well :(
Thats why I wanted to use the single image frame option to connect to the camera.
Regards,
PMS
