Events last hour blank
geraldbrandt
Post by geraldbrandt »
If the main page shows event happening in the last hour, clicking on the number shows 0 Events. If I click on the Day column, it shows me the day, and includes the events in the last hour.
I just did an upgrade from 1.33.10 (I think) to 1.33.14.
Gerald
geraldbrandt
Re: Events last hour blank
Is anyone seeing the same issue, or is it me?
Gerald
This would indicate that your event counts tables are out of sync.
You can try running zmaudit.pl to update them.
geraldbrandt
zmaudit.pl -c was already running. I killed it and ran zmaudit.pl from the command line.
I got a few of these: Deleted 10 log table entries by time
but not much else. Clicking on Last Hour Events still brings up a page with no events listed.
Gerald
Now I am suspecting a timezone problem. Aren't you gett lots of errors in logs about invalid timezone?
We moved the timezone setting from php.ini to Options -> System -> Timezone
mtader
Post by mtader »
It was a timezone issue for me. I needed to go into Options -> System -> Timezone and update to my timezone and the events appeared. THANKS!
