ZM-1.34 - porting to OpenWrt
rossbcan
Post by rossbcan »
Folks;
I am in process of porting ZM to OpenWrt (x86_64); part of this product portfolio: https://www.rossco.org
got past all the dependencies, config fails:
./zmconfgen.pl: Perl lib version (5.28.1) doesn't match executable '/usr/bin/perl' version (5.16.3) at /home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/target-x86_64_glibc/root-x86/usr/lib/perl5/5.28/Config.pm line 51
config seems to be detecting my system as opposed to openwrt perl, despite these Makefile settings:
CMAKE_OPTIONS += -DPERL_EXECUTABLE=$(STAGING_DIR_HOSTPKG)/usr/bin/perl$(PERL_VERSION) - correct perl executable
export PERL5LIB:=$(STAGING_DIR_ROOT)/usr/lib/perl$(PERL_MAJOR)/$(PERL_VERSION2) - correct perl libs
export PATH:=$(STAGING_DIR_HOSTPKG)/usr/bin:$(PATH) - point to correct perl path first
commenting /staging_dir/target-x86_64_glibc/root-x86/usr/lib/perl5/5.28/Config.pm:
#$^V eq 5.28.1
# or die sprintf "%s: Perl lib version (5.28.1) doesn't match executable '$^X' version (%vd)", $0, $^V;
gets past this, to:
[ 96%] Building ZoneMinder perl modules
Can't load '/home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/target-x86_64_glibc/root-x86/usr/lib/perl5/5.28/auto/Cwd/Cwd.so' for module Cwd: /home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/target-x86_64_glibc/root-x86/usr/lib/perl5/5.28/auto/Cwd/Cwd.so: undefined symbol: Perl_xs_boot_epilog at /home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/target-x86_64_glibc/root-x86/usr/lib/perl5/5.28/XSLoader.pm line 87
The missing symbol (Perl_xs_boot_epilog) is from libperl.so or built in to perl
nm -a staging_dir/hostpkg/usr/bin/perl | grep Perl_xs_boot_epilog
0000000000447b30 T Perl_xs_boot_epilog
...an indication that the first failure was correct: ZM is using system as opposed to openwrt perl.
So; how do I tell ZM to use the correct perl?
Thanks;
Bill
rossbcan
Re: ZM-1.34 - porting to OpenWrt
Post by rossbcan »
Successful ZM build:
touch /home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/target-x86_64_glibc/stamp/.zoneminder_installed
make[2]: Leaving directory `/home/rossb/OpenWrt/x86_64/r10508/openwrt/Custom/new/zoneminder'
What I had to do was (temporarily break my build host perl) and undo the Config.pm comments above:
mv /usr/bin/perl /usr/bin/perl_orig
ln -sf /home/rossb/OpenWrt/x86_64/r10508/openwrt/staging_dir/hostpkg/usr/bin/perl5.28.1 /usr/bin/perl
However ZM make hardcodes perl, it is unacceptable for cross compile
In addition to needing an answer how to configure ZM to use an alternate perl...
I suggest the developers create two variables (in config file., cmake variables or env):
TARGET_PERL and HOST_PERL, both defaulting to "/usr/bin/perl" to maintain existing behavior
this will fix cross-compile.
Regards;
Bill
good idea with the TARGET_PERL and HOST_PERL
rossbcan
Post by rossbcan »
or just use first perl found in path for compile, leave at /usr/bin/perl for target executables / scripts...
I'll take a look at that. Keep us posted about the port.
rossbcan
Post by rossbcan »
Still need a fix for specifying build perl path.
Status - Integration testing onvf: no response:
root@SecureOffice:~# /usr/bin/zmonvif-probe.pl -v probe
Name "ZoneMinder::ONVIF::verbose" used only once: possible typo at /usr/bin/zmonvif-probe.pl line 81.
Probing for SOAP 1.1
<Fault xmlns="http://schemas.xmlsoap.org/soap/envelop ... ring>Error sending / receiving message: Timed out waiting for response</faultstring><faultactor>urn:localhost</faultactor></Fault>
Probing for SOAP 1.2
I have multiple ethernet interfaces. May need to modify zmonvif-probe.pl to specify multicast interface?
Regards;
Bill
rossbcan
Post by rossbcan »
I am at the point where an IP camera is streaming to ZM and can see the packet traffic in firefox console, but no video.
Suspect I am missing a dependency. Anyone have a current dependency list?
Compiled https://github.com/ZoneMinder/zoneminder.git version e390195ebbcd21bf0ca96dd400811c22ca1773cc (master, downloaded Aug 14) from source
To create a dependency list (on as new a distribution as possible):
ubuntu: apt-cache depends zoneminder
Thanks;
Bill
ramponis
Post by ramponis »
Hi rossbcan, can you share your make file?
I'm interested to use it on my openwrt x86
Thank you
