Page 1 of 1
Two-way audio support
Posted: Mon Jun 17, 2019 4:40 pm
by viktr
Hi there,
Cannot find an answer, please help. Is it possible to use two-way audio in ZM? I have downloaded 1.32.3 for debian 9.9 and added my hikvision DS-2CD2455FWD-IW camera. It works ok, but it has internal speaker and I cannot find how to configure it.The camera itself is configured as ffmpeg rtsp source. Is it possible to use it's speaker somehow?
Thank you
Re: Two-way audio support
Posted: Mon Jun 17, 2019 8:18 pm
by thefuzz4
At this time ZM does not support live streaming of audio. It only supports recording the audio with a recording. Also keep in mind your local laws in regards to recording the audio without informing the 2nd party.
Posted: Tue Jun 18, 2019 6:58 am
by viktr
That’s sad. Well, thank you, been searching for that for a while, met some mentions about 2-way audio. Btw, if i’ve got an ip camera with 2-way audio, and this camera is accessible via rtsp, does the audio channel to the camera streams via the same rtsp connection? Just want to understand is it difficult to add such a support.
Regarding local law - I’m not a lawyer but I suppose I can do whatever I want in my own house ) Thank you for warning anyway
Posted: Tue Jun 18, 2019 4:40 pm
by mikb
viktr wrote: Tue Jun 18, 2019 6:58 am I’m not a lawyer
I think that's the only accurate bit of your last sentence.
It depends what country you are in, and whether "the public" could be recorded by your "bugging device", and also whether it is considered OK to record people's conversations without their consent or knowledge -- even in your own home, and what you do with those recordings.
Generally, adding audio to a recording adds a new dimension of legal problems to those you already had. Consult a lawyer, as you are not one :)
