Silly-high capture rates
Posted: Wed Sep 12, 2018 5:38 pm
I've been running for many months (all year- since I've installed ZM) w/o errors like this. Just got this error (several of many):
ZM/webserver was unresponsive when I can across this (so I rebooted server, thinking it was another instance of the wireless interface locking up*). Once up I spotted the entries in the logs.
* Apparently an iv6 Debian and Intel issue?
How the heck can this occur? There have been zero changes. Last server reboot had been 9 days prior: Not uncommon (expected) to see capture rate being throttled back (though only here and there). Quad-core i5, whose loads never really get much above 1 (occasionally bump up under 2, but essentially the CPU isn't working hard). Disk is less than 10% and /dev/shm is around 20% (currently, which seems a little high). Server is dedicated to only running ZM.
Have four cameras and all were reporting high capture rates. I do NOT have any max capture rate set. FPS analysis is 1. Until now I've only seen ZM capture rate being reported (via logs) at around 5.Camera4: 521000 - Capturing at 1000.00 fps
