Cron scheduling question
ngauruhoe
Post by ngauruhoe »
Hi, I'm trying to follow the example in the doc here: http://zoneminder.readthedocs.io/en/lat ... on-example. But not much luck so far. This is what I tried and the result:
1) Added to root crontab (sudo -s and using crontab -e):
0 22 * * 0-6 root /usr/bin/zmpkg.pl Test
cron.log shows:
CRON[3562]: (root) CMD (root /usr/bin/zmpkg.pl Test)
ZM console shows no difference, i.e. not the Test run state
2) Added to ZM (user skywalker) crontab:
0 22 * * 0-6 skywalker /usr/bin/zmpkg.pl Test
cron.log shows:
CRON[3735]: (skywalker) CMD (skywalker /usr/bin/zmpkg.pl Test)
3) I also tried the 2nd one but with 'sudo' in front of the /usr/bin/......... No difference, no state change
Btw, Ubuntu is 15.10 and zmpkg.pl is in /usr/bin (and not in /usr/local/bin).
What can I try next? Appreciate your help!
Mike
ps. ZM run state Test exists of course.......If anyone would wonder
Re: Cron scheduling question
My recommendation is to install Webmin if you are not a Linux command line guru. Webmin puts many tasks, including cron, into a web gui which is easy!
ngauruhoe
Post by ngauruhoe »
I may, but I'dd like to learn and understand what it is that I am doing incorrectly. Any clue's?
Thank you.
ngauruhoe
Post by ngauruhoe »
Also got this figured out at last. I initially followed the syntax of the cron entries already in root's crontab. The six'th field of every entry in there was the uid ('root'). So, that's what I used as well in the entries I added. But in the cronlog the resulting commands seem to start with the uid. After removing it, everything works fine. Run states are nicely changed at the specified times. See below.
# m h dom mon dow user  command
17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --repo$
0  8    * * 1-5         /usr/bin/zmpkg.pl Weekday_Daytime
0 20    * * 1-5         /usr/bin/zmpkg.pl Weekday_Nighttime
0 8     * * 6           /usr/bin/zmpkg.pl Weekend
# 36 22 * * 0-6   /usr/bin/zmpkg.pl Test
I have no clue why my entries do not work with a uid and the original entries do work with it. If anyone knows......I still like to learn......
mikb
Post by mikb »
On my Slackware systems, no crontab entries have a user field.
Try "man crontab" on your system and read what it says about the fields -- I've just skimmed mine and see nothing about handing off to other users, the crontab file called "root" runs the rooty things, a crontab file called "myuser" would run them as "myuser" etc. -- they are not lumped into one file. Maybe yours are?
Maybe you have a more advanced version of cron?
Or maybe you have a script/binary called "root" which runs the following arguments as root for some reason? A bit like "sudo something" :)
Try "which root" or "whereis root" to see if it coughs up a clever helper script -- I don't have one!
Baylink
Post by Baylink »
Crons are one of the most widely disparate -- and least well documented -- facilities amongst *nix distros.
I think the one that takes the username as a column is the 'Vixie' cron, written by Paul Vixie, late of DEC. Usually, the /etc/crontab takes the username, and the ones in /var/spool/cron/crontabs/$USERNAME don't... but what I've *never* seen is one where a single crontab has both types.
mikb
Post by mikb »
Slackware: "Our crontab format is roughly similar to that used by vixiecron. " :)
So the "roughly similar" is probably where all this diverges.
I don't have an /etc/crontab (although there are /etc/cron.d - empty, and /etc/cron.[hourly/daily/monthly/weekly] which just contain scripts to directly execute, not a "crontab" fornatted file in sight.
ngauruhoe
Post by ngauruhoe »
Thanks for the answers. The 'whereis root' etc. didn't show much.
Directly editing (nano /etc/crontab) or becoming root and editing through crontab -e results in editing the same, system-wide, crontab. The answer is in the header where it explains how the system-wide is different from a user crontab.
It still doesn't explain though why my entries, without the user, do work. Hard to see how a positional field may be skipped. Perhaps the logic is smart enough to figure out that something with a '/' cannot be a user name and subsequently defaults to root because it is the system-wide crontab.
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. [b]These files also have username fields,
# that none of the other crontabs do.[/b]
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow [b]user[/b] command
25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
