Vanxse Camera
PCMedicJAX
Vanxse Camera
Post by PCMedicJAX »
I have purchased several Vanxse cameras "cannot find model number anywhere" in hopes that they would work wirh zoneminder. they claim that they work with onvif and rtsp. I am unable to find the correct remote hostpath to use it with http. I have only been able to see the camera using their viewer in Internet explorer. I have read through the source of the page in IE but cannot determint the path to the stream. any help is greatly appreciates
Re: Vanxse Camera
If they are onvif compliant, then try the onvif probe method.
Re: Vanxse Camera
Oh, but first upgrade to 1.30.4, it has better onvif support and a ton of security fixes.
PCMedicJAX
Re: Vanxse Camera
in 1.29 probe does not find the camera. I will try to upgrade. Thanks
PCMedicJAX
Re: Vanxse Camera
I tried to up grade using the command line
apt-get upgrade zoneminder
but that didn't do you by chance know the command to use in Raspbian Jessie
Re: Vanxse Camera
PCMedicJAX
Re: Vanxse Camera
Is this going to upgrade the existing install or wipe it out and install from scratch? And I just noticed that those instructions are for installing 1.29
Re: Vanxse Camera
I'm not sure if there is a Zoneminder 1.30.x for Debian 8. There is an install for Debian 9. Ubuntu may be a better choice for the Pi.
PCMedicJAX
Re: Vanxse Camera
what version of Ubuntu would you recommend for a RPI3? I will only be running zoneminder on it.
PCMedicJAX
Re: Vanxse Camera
I found this link http://zoneminder.blogspot.com/p/raspberry-pi-3.html that is using fedora but I can't figure out what version of zoneminder is being used.
