Page 1 of 1
Unable to send stream frame: Broken pipe anytime closing live stream
Posted: Sun Apr 30, 2017 6:02 am
by bulldog
I'm running Zoneminder v1.30.0 in a FreeBSD Jail. Everything works fine except this error that I get anytime I close the live stream window and the zms process ends it looks like. I can open the live stream back up, and camera works fine, goto close it. and it writes another ERR entry of this in the log, it'll go on as many times as i do it. Any ideas? I couldn't find anything on google or the forums.
zms 102005 ERR Unable to send stream frame: Broken pipe zm_monitor.cpp 3927
Re: Unable to send stream frame: Broken pipe anytime closing live stream
Posted: Sun Apr 30, 2017 1:28 pm
by knight-of-ni
This is by design, and it doesn't happen all the time. It's simply telling you that the connection to the client stopped, which it has.
Downgrading the message to Info might be appropriate.
Posted: Sun Apr 30, 2017 10:07 pm
by bulldog
knnniggett wrote: Sun Apr 30, 2017 1:28 pm This is by design, and it doesn't happen all the time. It's simply telling you that the connection to the client stopped, which it has.
It DOES happen every single time. Every single time i open the live stream, and close it, It writes this ERR message to the log.
Posted: Sun Apr 30, 2017 10:22 pm
by knight-of-ni
bulldog wrote: Sun Apr 30, 2017 10:07 pm It DOES happen every single time. Every single time i open the live stream, and close it, It writes this ERR message to the log.
Maybe for you, but not everyone else.
Regardless of how many times it happens, that error by itself is not an indication there is something wrong with your system.
Posted: Mon May 01, 2017 5:28 am
by bulldog
So if its "simply telling you the connection to the client stopped" then why would it only happen when it feels like? The connection stops to the client whenever the live stream ends. I'm sure i'm not the only person who seems to have it happen every time.
Either way. how can this be eliminated? It causes my Log to turn to an alert state which is false.
Posted: Mon May 01, 2017 12:15 pm
by knight-of-ni
Go back and re-read everything I've said, especially the first response. You're acting as though I told you I wasn't going to do anything about this, when in fact I told you exactly what I was intending to do, in my very first response! If something isn't clear to you or you don't understand what I said, then feel free to ask questions. However, I will spend my free time helping someone else if you continue to make arguments based on false assumptions.
Posted: Mon May 01, 2017 12:18 pm
by rockedge
turn off the logs.....I have setups that work but spit errors all day.......I don't see them because there not there...result...no worries.
Posted: Fri May 04, 2018 4:32 pm
by bulldog
Any update on downgrading this ERR event?
Posted: Mon Jun 04, 2018 9:39 pm
by elchavodel8
I have same error every time i see recorded events and close them
Posted: Tue Jul 24, 2018 5:03 pm
by pat2
knight-of-ni wrote: Sun Apr 30, 2017 1:28 pm This is by design, and it doesn't happen all the time. It's simply telling you that the connection to the client stopped, which it has.
hi knight,
i'm receiveng the same error message. I understood that is by design. In my case it happens all the time i close a recorded stream.
Since it's annoying please could you explain how it is possible to downgrade the message.
thanks.
Posted: Fri May 24, 2019 1:58 am
by Redstorm
Same here, needs to be downgraded to INFO instead of ERROR
Zoneminder 1.32.3
Posted: Tue Feb 22, 2022 5:10 am
by narad
Zoneminder 1.36.12
This still shows as a warning, turning my otherwise nice green log button into yellow...
Feels like downgrading this to INFO, or even DEBUG would be nice.
I noticed it is correlated in my system with disk caching memory utilization going up (as shown in htop, also in yellow, in a suspicious coincidence :-) ).
Is there any chance it is related to the speed of the storage device and rate of recording?
