Page 1 of 1
API
Posted: Mon Feb 08, 2016 10:04 am
by Ryuk
Hi, I have recently made a server for CCTV and i was wondering if there is a way to install APIs, I found something on the internet but not useful to me.
using 1.26 version.
Re: API
Posted: Mon Feb 08, 2016 10:18 am
by SteveGilvarry
API was released in 1.29.0
Re: API
Posted: Mon Feb 08, 2016 11:33 am
by Ryuk
SteveGilvarry wrote:API was released in 1.29.0
So, there is a way to upgrade my zoneminder without losing configurations etc.. or just to install apis?
Re: API
Posted: Mon Feb 08, 2016 6:17 pm
by bbunge
Check the WIKI. If you use Ubuntu there are upgrade instructions to get you to 1.29.0
Re: API
Posted: Tue Feb 09, 2016 10:30 am
by Ryuk
bbunge wrote:Check the WIKI. If you use Ubuntu there are upgrade instructions to get you to 1.29.0
Alright! I found a solution right here -->
http://blog.waldrondigital.com/tag/zoneminder-upgrade/
Thanks for the tips.
Re: API
Posted: Tue Feb 09, 2016 3:56 pm
by bbunge
I would advise against using that as it is old.
Look here:
https://wiki.zoneminder.com/Ubuntu
