Apexis APM-J602
mobius
Apexis APM-J602
Post by mobius »
Just got this new cam, planning to use it on my front porch. I can browse to camIP/videostream.cgi?user=admin&pwd=1234 and see the stream fine, but this does not work in the ZM config. Any thoughts? I think I'm missing something minor but cannot figure it out.
Re: Apexis APM-J602
More info on what you used to set it up in ZM?
bb
mobius
Re: Apexis APM-J602
Post by mobius »
Hi bbunge,
I used remote source type, http protocol, simple method, ip for remote host name, remote host port 80, remote host path is /videostream.cgi?user=admin&pwd=1234, 24bit color, 640 width, 480 height. This cam sems to be the same as the two other foscams I'm running. The remote host path works fine in the browser, which is why I'm wondering what the issue is for zm to see it. I just get a black box, no video feed.
