Page 1 of 1
Skin problems
Posted: Mon Apr 27, 2015 10:25 am
by lsmr
I just tried to change zoneminder skin in the options to mobile skin, but with this one don't show all the things and now I can't put the classic skin.
When I try to go to options thought: /index.php?view=options&tab=skins
Just show the message: "View 'options' does not exist" and I can't put it back.
How can I fix this??
Re: Skin problems
Posted: Mon Apr 27, 2015 12:41 pm
by chippy99
There is a cookie called zmSkin, if you delete that zm should then use default skin.
Re: Skin problems
Posted: Mon Apr 27, 2015 12:51 pm
by chippy99
Just remebered you can also do ?skin=flat or ?skin=classic at the end of your url. eg http://192.168.0.1/zm/index.php?skin=flat
Re: Skin problems
by asker
Force it back with this:
http:/yourIP:port/zm/?skin=classic
lsmr wrote:Hi,
