Grabbing one still image
BiloxiGeek
Post by BiloxiGeek »
Is there a method to grab an still image from a monitor that is in an idle state? I don't want to force an alarm or set the monitor to record, I just want to grab one image from the feed. The camera is IP based. Events work nicely, but I find occasional instances where I'd like to grab one image that I can save to my local system without forcing an alarm or waiting for one to happen naturally.
mikb
Re: Grabbing one still image
Post by mikb »
BiloxiGeek wrote:Is there a method to grab an still image from a monitor that is in an idle state?.
If you don't find a ZM way to do this, why not go direct to the camera and dump out the JPG from its still-image interface?
e.g. wget or curl from "http://yourcamera/image.jpg" into a file?
Most IP Cameras have a still URL, a video URL, as well as the management and setup pages. Also, most will support more than one client, so it won't interfere with ZM.
BiloxiGeek
That works when I'm at home on the local network. I was hoping for a way to do it via the ZM web interface so I don't have to log in remotely, then run a grab script (or whatever), then transfer the image outside the network. I already have a NAT rule so I can see my ZM setup from remote, so why not just grab a single image from that interface.
mikb
Post by mikb »
OK, that's a valid reason, I'll give you that one! :)
I'm not sure how to do it from ZM though.
