Screen Monitor empty - TRENDnet
HartyShow
Post by HartyShow »
Hi all,
First time, sorry for my english ^^.
I fresh install one server with CentOS 6.5 x86_64 and zonemidner 1.27.
I follow howto in this website and another one for completion
Installation is OK, so I look wiki for my cam (TRENDnet TV-IP262P and TV-IP310PI) but in monitor mode a haven't image and many error log.
With vlc (on my older Ubuntu 10.04), screen it's OK (I show spec ofr replicating image size on zoneminder).
Server spec fstab:
/dev/mapper/VG_SYS-LV_SYSTEM	/	ext4	defaults	1	1
UUID=76950053-3939-43d1-9143-c449295f228d	/boot	ext4	defaults,nodev,nosuid,noexec	1	2
/dev/mapper/VG_SYS-LV_HOME	/home	ext4	defaults,nodev,nosuid,noexec	1	2
/dev/mapper/VG_SYS-LV_OPT	/opt	ext4	defaults,nodev	1	2
#/dev/mapper/VG_SYS-LV_TMP	/tmp	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_SYS-LV_TMP	/tmp	ext4	defaults,nosuid	1	2
/dev/mapper/VG_SYS-LV_USR	/usr	ext4	defaults,nodev	1	2
/dev/mapper/VG_SYS-LV_USR_LOCAL	/usr/local	ext4	defaults,nodev	1	2
/dev/mapper/VG_SYS-LV_VAR	/var	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_SYS-LV_VAR_LOG_ZM	/var/log/zm	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_ZM-LV_ZM_EVENTS	/var/www/html/zm/events	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_SYS-LV_VAR_BACKUP	/var/backup	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_SYS-LV_VAR_LIB_MYSQL	/var/lib/mysql	ext4	defaults,noexec,nodev,nosuid	1	2
/dev/mapper/VG_SYS-LV_SWAP	swap	swap	defaults	0	0
tmpfs	/dev/shm	tmpfs	defaults	0	0
devpts	/dev/pts	devpts	gid=5,mode=620	0	0
sysfs	/sys	sysfs	defaults	0	0
proc	/proc	proc	defaults	0	0
/tmp	/var/tmp	none  	rw,noexec,nosuid,nodev,bind	0 0
Error log when In launch monitor mode on TV-IP262P:
2014-08-26 22:41:59.734540	zmdc	1774	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
2014-08-26 22:41:59.677410	zmdc	1774	ERR	'zmc -m 2' exited abnormally, exit status 6	zmdc.pl
2014-08-26 22:41:59.634500	zmc_m2	3117	INF	addr2line -e /usr/local/bin/zmc 0x479ef6 0x7f508e3ac710 0x7f508d2c7925 0x7f508d2c9105 0x7f508d305837 0x7f508d30b166 0x481b6a 0x445c55 0x407f1a 0x7f508d2b3d1d 0x406b49	zm_signal.cpp	106
2014-08-26 22:41:59.631059	zmc_m2	3117	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	105
2014-08-26 22:41:59.627527	zmc_m2	3117	ERR	Backtrace 10: /usr/local/bin/zmc() [0x406b49]	zm_signal.cpp	98
2014-08-26 22:41:59.624093	zmc_m2	3117	ERR	Backtrace 9: /lib64/libc.so.6(__libc_start_main+0xfd) [0x7f508d2b3d1d]	zm_signal.cpp	98
2014-08-26 22:41:59.620635	zmc_m2	3117	ERR	Backtrace 8: /usr/local/bin/zmc() [0x407f1a]	zm_signal.cpp	98
2014-08-26 22:41:59.617310	zmc_m2	3117	ERR	Backtrace 7: /usr/local/bin/zmc() [0x445c55]	zm_signal.cpp	98
2014-08-26 22:41:59.613200	zmc_m2	3117	ERR	Backtrace 6: /usr/local/bin/zmc() [0x481b6a]	zm_signal.cpp	98
2014-08-26 22:41:59.609995	zmc_m2	3117	ERR	Backtrace 5: /lib64/libc.so.6(+0x76166) [0x7f508d30b166]	zm_signal.cpp	98
2014-08-26 22:41:59.606707	zmc_m2	3117	ERR	Backtrace 4: /lib64/libc.so.6(+0x70837) [0x7f508d305837]	zm_signal.cpp	98
2014-08-26 22:41:59.602322	zmc_m2	3117	ERR	Backtrace 3: /lib64/libc.so.6(abort+0x175) [0x7f508d2c9105]	zm_signal.cpp	98
2014-08-26 22:41:59.593126	zmc_m2	3117	ERR	Backtrace 2: /lib64/libc.so.6(gsignal+0x35) [0x7f508d2c7925]	zm_signal.cpp	98
2014-08-26 22:41:59.589806	zmc_m2	3117	ERR	Backtrace 1: /lib64/libpthread.so.0(+0xf710) [0x7f508e3ac710]	zm_signal.cpp	98
2014-08-26 22:41:59.586376	zmc_m2	3117	ERR	Backtrace 0: /usr/local/bin/zmc() [0x479ef6]	zm_signal.cpp	98
2014-08-26 22:41:59.582697	zmc_m2	3117	ERR	Signal address is 0x3000000c2d, from 0x7f508d2c7925	zm_signal.cpp	77
2014-08-26 22:41:59.572524	zmc_m2	3117	ERR	Got signal 6 (Aborted), crashing	zm_signal.cpp	54
2014-08-26 22:41:59.565072	zmc_m2	3117	ERR	Unable to get response	zm_remote_camera_http.cpp	1110
2014-08-26 22:41:59.561485	zmc_m2	3117	ERR	Unable to read subheader	zm_remote_camera_http.cpp	938
2014-08-26 22:41:59.557537	zmc_m2	3117	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	162
2014-08-26 22:41:59.553923	zmc_m2	3117	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-08-26 22:41:59.550010	zmdc	1774	INF	'zmc -m 2' stopping at 14/08/26 22:41:59	zmdc.pl
2014-08-26 22:41:59.490400	zmdc	1774	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
2014-08-26 22:41:54.927549	web_php	2270	ERR	socket_sendto( /tmp/zm/zms-109898s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-26 22:40:34.129620	zmc_m2	3117	INF	Cam_salon: 4000 - Capturing at 10.00 fps	zm_monitor.cpp	2831
2014-08-26 22:39:40.357171	web_php	2267	ERR	socket_sendto( /tmp/zm/zms-163882s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-26 22:39:34.348625	web_js	2271	ERR	getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-163882s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2014-08-26 22:39:34.260693	web_php	2269	ERR	socket_sendto( /tmp/zm/zms-163882s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-26 22:38:54.121996	zmc_m2	3117	INF	Cam_salon: 3000 - Capturing at 10.00 fps	zm_monitor.cpp	2831
2014-08-26 22:37:14.037711	zmc_m2	3117	INF	Cam_salon: 2000 - Capturing at 9.90 fps	zm_monitor.cpp	2831
2014-08-26 22:35:33.997127	zmc_m2	3117	INF	Cam_salon: 1000 - Capturing at 10.00 fps	zm_monitor.cpp	2831
2014-08-26 22:34:27.396289	web_php	2268	ERR	socket_sendto( /tmp/zm/zms-453021s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-26 22:33:53.652432	zmc_m2	3117	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:33:53.647095	zmc_m2	3117	ERR	Zone 2/All for monitor Cam_salon extends outside of image dimensions, (0,0), (12499,1023), ignoring	zm_zone.cpp	966
2014-08-26 22:33:53.324960	zmdc	1774	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
2014-08-26 22:33:53.263020	zmdc	3117	INF	'zmc -m 2' started at 14/08/26 22:33:53	zmdc.pl
2014-08-26 22:33:53.262980	zmdc	1774	INF	'zmc -m 2' starting at 14/08/26 22:33:53, pid = 3117	zmdc.pl
2014-08-26 22:33:53.204320	zmdc	1774	WAR	Can't find process with command of 'zmc -m 2'	zmdc.pl
2014-08-26 22:33:53.144480	zmdc	1774	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
Conf Cam:
Remote Protocol: HTTP
Remote Method	: Simple
Remote Host Name:	User:Password@IP
Remote Host Port:	80
Remote Host Path:	cgi/mjpg/mjpg.cgi
Target Colorspace:	24 bit
Capture Width (pixels)	: 1280 (see with vlc)
Capture Height (pixels)	: 1024 (see with vlc)
Error log when In launch monitor mode on IP310P:
2014-08-26 22:44:05.006390	zmdc	1774	WAR	Can't find process with command of 'zma -m 3'	zmdc.pl
2014-08-26 22:44:04.948550	zmdc	1774	INF	Command 'zmc -m 3' removed from pending list at 14/08/26 22:44:04	zmdc.pl
2014-08-26 22:44:04.889210	zmdc	1774	WAR	Can't find process with command of 'zma -m 3'	zmdc.pl
2014-08-26 22:43:53.145970	zmdc	1774	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2014-08-26 22:43:53.126271	zmc_m3	3287	FAT	Unable to open input admin:admin@172.18.250.13/streaming/channels/1 due to: Success	zm_ffmpeg_camera.cpp	120
2014-08-26 22:43:53.122641	zmc_m3	3287	INF	Priming capture from admin:admin@172.18.250.13/streaming/channels/1	zm_ffmpeg_camera.cpp	112
2014-08-26 22:43:53.118962	zmc_m3	3287	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:43:53.060130	zmdc	3287	INF	'zmc -m 3' started at 14/08/26 22:43:53	zmdc.pl
2014-08-26 22:43:53.060090	zmdc	1774	INF	'zmc -m 3' starting at 14/08/26 22:43:53, pid = 3287	zmdc.pl
2014-08-26 22:43:53.045540	zmdc	1774	INF	Starting pending process, zmc -m 3	zmdc.pl
2014-08-26 22:43:47.808314	web_php	2267	ERR	socket_sendto( /tmp/zm/zms-587319s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-26 22:43:33.111170	zmdc	1774	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2014-08-26 22:43:33.104460	zmc_m3	3280	FAT	Unable to open input admin:admin@172.18.250.13/streaming/channels/1 due to: Success	zm_ffmpeg_camera.cpp	120
2014-08-26 22:43:33.100985	zmc_m3	3280	INF	Priming capture from admin:admin@172.18.250.13/streaming/channels/1	zm_ffmpeg_camera.cpp	112
2014-08-26 22:43:33.097321	zmc_m3	3280	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:43:33.037680	zmdc	3280	INF	'zmc -m 3' started at 14/08/26 22:43:33	zmdc.pl
2014-08-26 22:43:33.037640	zmdc	1774	INF	'zmc -m 3' starting at 14/08/26 22:43:33, pid = 3280	zmdc.pl
2014-08-26 22:43:33.031130	zmdc	1774	INF	Starting pending process, zmc -m 3	zmdc.pl
2014-08-26 22:43:23.112560	zmdc	1774	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2014-08-26 22:43:23.093694	zmc_m3	3275	FAT	Unable to open input admin:admin@172.18.250.13/streaming/channels/1 due to: Success	zm_ffmpeg_camera.cpp	120
2014-08-26 22:43:23.089686	zmc_m3	3275	INF	Priming capture from admin:admin@172.18.250.13/streaming/channels/1	zm_ffmpeg_camera.cpp	112
2014-08-26 22:43:23.085904	zmc_m3	3275	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:43:23.027210	zmdc	3275	INF	'zmc -m 3' started at 14/08/26 22:43:23	zmdc.pl
2014-08-26 22:43:23.027180	zmdc	1774	INF	'zmc -m 3' starting at 14/08/26 22:43:23, pid = 3275	zmdc.pl
2014-08-26 22:43:23.017610	zmdc	1774	INF	Starting pending process, zmc -m 3	zmdc.pl
2014-08-26 22:43:18.137410	zmdc	1774	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2014-08-26 22:43:18.130906	zmc_m3	3262	FAT	Unable to open input admin:admin@172.18.250.13/streaming/channels/1 due to: Success	zm_ffmpeg_camera.cpp	120
2014-08-26 22:43:18.127265	zmc_m3	3262	INF	Priming capture from admin:admin@172.18.250.13/streaming/channels/1	zm_ffmpeg_camera.cpp	112
2014-08-26 22:43:18.123267	zmc_m3	3262	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:43:18.065080	zmdc	3262	INF	'zmc -m 3' started at 14/08/26 22:43:18	zmdc.pl
2014-08-26 22:43:18.065050	zmdc	1774	INF	'zmc -m 3' starting at 14/08/26 22:43:18, pid = 3262	zmdc.pl
2014-08-26 22:43:18.060210	zmdc	1774	INF	Starting pending process, zmc -m 3	zmdc.pl
2014-08-26 22:43:18.056420	zmdc	1774	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2014-08-26 22:43:18.049763	zmc_m3	3254	FAT	Unable to open input admin:admin@172.18.250.13/streaming/channels/1 due to: Success	zm_ffmpeg_camera.cpp	120
2014-08-26 22:43:18.042699	zmc_m3	3254	INF	Priming capture from admin:admin@172.18.250.13/streaming/channels/1	zm_ffmpeg_camera.cpp	112
2014-08-26 22:43:18.042180	zmdc	1774	WAR	Can't find process with command of 'zma -m 3'	zmdc.pl
2014-08-26 22:43:18.039098	zmc_m3	3254	INF	Starting Capture	zmc.cpp	195
2014-08-26 22:43:17.980900	zmdc	3254	INF	'zmc -m 3' started at 14/08/26 22:43:17	zmdc.pl
2014-08-26 22:43:17.980570	zmdc	1774	INF	'zmc -m 3' starting at 14/08/26 22:43:17, pid = 3254	zmdc.pl
2014-08-26 22:43:17.922280	zmdc	1774	WAR	Can't find process with command of 'zmc -m 3'	zmdc.pl
2014-08-26 22:43:17.863480	zmdc	1774	WAR	Can't find process with command of 'zma -m 3'	zmdc.pl
Conf Cam:
Source Type: Ffmpeg
Source Path: USER:PASSWORD@IP/streaming/channels/1
Capture Height (pixels)	: 720 (see with vlc)
I hope you can help me, thank you :D
HartyShow
Re: Screen Monitor empty - TRENDnet
Post by HartyShow »
Hi all,
When I active Monitor mode, I have in log:
2014-08-30 17:08:39.669960	zmdc	1936	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
2014-08-30 17:08:35.629743	web_js	4302	ERR	getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-015266s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2014-08-30 17:08:35.604990	web_php	4306	ERR	socket_sendto( /tmp/zm/zms-015266s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
2014-08-30 17:08:31.343988	zmc_m2	4336	INF	Starting Capture	zmc.cpp	195
2014-08-30 17:08:31.340106	zmc_m2	4336	ERR	Zone 2/All for monitor Cam_salon extends outside of image dimensions, (0,0), (12499,1023), ignoring	zm_zone.cpp	966
2014-08-30 17:08:30.885550	zmdc	1936	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
2014-08-30 17:08:30.823850	zmdc	4336	INF	'zmc -m 2' started at 14/08/30 17:08:30	zmdc.pl
2014-08-30 17:08:30.823510	zmdc	1936	INF	'zmc -m 2' starting at 14/08/30 17:08:30, pid = 4336	zmdc.pl
2014-08-30 17:08:30.764270	zmdc	1936	WAR	Can't find process with command of 'zmc -m 2'	zmdc.pl
2014-08-30 17:08:30.705530	zmdc	1936	WAR	Can't find process with command of 'zma -m 2'	zmdc.pl
When I desactivate Monitor Mode (from monitor to "None"), I have in TTy this syslog message:
Message from syslogd@FouDuRouax at Aug 30 17:08:39 ...
 * glibc detected *** /usr/local/bin/zmc: free(): invalid pointer: 0x00007ffd870b3ee8 ***
 ===== Backtrace: =========
 ib64/libc.so.6(+0x76166)[0x7ffd86d9a166]
 sr/local/bin/zmc[0x481b6a]
 sr/local/bin/zmc[0x445c55]
 sr/local/bin/zmc[0x407f1a]
 ib64/libc.so.6(__libc_start_main+0xfd)[0x7ffd86d42d1d]
 sr/local/bin/zmc[0x406b49]
 ===== Memory map: ========
 lib64/libgpg-error.so.0.5.0
7ffd7fa2c000-7ffd7fa2d000000 r--p 00002000 fd:00 275                        /lib64/libgpg-error.so.0.5.0#0127ffd7fa2d000-7ffd7fa2e000 rw-p 00003000 fd:00 275                        /lib64/libgpg-error.so.0.5.0#0127ffd7fa2e000-7ffd7fa3e000 r-xp 00000000 fd:04 11147                      /usr/lib64/libtasn1.so.3.1.6#0127ffd7fa3e000-7ffd7fc3d000 ---p 00010000 fd:04 11147                      /usr/lib64/libtasn1.so.3.1.6#0127ffd7fc3d000-7ffd7fc3e000 rw-p 0000f000 fd:04 11147                      /usr/lib64/libtasn1.so.3.1.6#0127ffd7fc3e000-7ffd7fc40000 r-xp 00000000 fd:04 5290                       /usr/lib64/libXau.so.6.0.0#0127ffd7fc40000-7ffd7fe40000 ---p 00002000 fd:04 5290                       /usr/lib64/libXau.so.6.0.0#0127ffd7fe40000-7ffd7fe41000 rw-p 00002000 fd:04 5290                       /usr/lib64/libXau.so.6.0.0#0127ffd7fe41000-7ffd7fe5e000 r-xp 00000000 fd:00 5438                       /lib64/libselinux.so.1#0127ffd7fe5e000-7ffd8005d000 ---p 0001d000 fd:00 5438                       /lib64/libselin
 .so.1
7ffd8005d000-7ffd8005e000000 r--p 0001c000 fd:00 5438                       /lib64/libselinux.so.1#0127ffd8005e000-7ffd8005f000 rw-p 0001d000 fd:00 5438                       /lib64/libselinux.so.1#0127ffd8005f000-7ffd80060000 rw-p 00000000 00:00 0 #0127ffd80060000-7ffd800d1000 r-xp 00000000 fd:00 96                         /lib64/libfreebl3.so#0127ffd800d1000-7ffd802d0000 ---p 00071000 fd:00 96                         /lib64/libfreebl3.so#0127ffd802d0000-7ffd802d2000 r--p 00070000 fd:00 96                         /lib64/libfreebl3.so#0127ffd802d2000-7ffd802d3000 rw-p 00072000 fd:00 96                         /lib64/libfreebl3.so#0127ffd802d3000-7ffd802d7000 rw-p 00000000 00:00 0 #0127ffd802d7000-7ffd802dc000 r-xp 00000000 fd:04 37030                      /usr/lib64/libogg.so.0.6.0#0127ffd802dc000-7ffd804dc000 ---p 00005000 fd:04 37030                      /usr/lib64/libogg.so.0.6.0#0127ffd804dc000-7ffd804dd000 rw-p 00005000 fd:04 37030                      /usr/lib64/libogg.so.0.6.0#0127ffd804dd000-7ffd80551000 r-xp 00000000 fd:04 3686
                      /usr/lib64/liboil-0.3.so.0.3.0#0127ffd80551000-7ffd80750000 ---p 00074000 fd:04 36869                      /usr/lib64/liboil-0.3.so.0.3.0#0127ffd80750000-7ffd8076b000 rw-p 00073000 fd:04 36869                      /usr/lib64/liboil-0.3.so.0.3.0#0127ffd8076b000-7ffd8076e000 rw-p 00000000 00:00 0 #0127ffd8076e000-7ffd807e0000 r-xp 00000000 fd:00 278                        /lib64/libgcrypt.so.11.5.3#0127ffd807e0000-7ffd809df000 ---p 00072000 fd:00 278                        /lib64/libgcrypt.so.11.5.3#0127ffd809df000-7ffd809e0000 r--p 00071000 fd:00 278                        /lib64/libgcrypt.so.11.5.3#0127ffd809e0000-7ffd809e3000 rw-p 00072000 fd:00 278                        /lib64/libgcrypt.so.11.5.3#0127ffd809e3000-7ffd80a7f000 r-xp 00000000 fd:04 15646                      /usr/lib64/libgnutls.so.26.14.12#0127ffd80a7f000-7ffd80c7f000 ---p 0009c000 fd:04 15646                      /usr/lib64/libgnutls.so.26.14.12#0127ffd80c7f000-7ffd80c86000 rw-p 0009c000 fd:04 15646                      /usr/lib64/libgnutls.so.26.1
 12
7ffd80c86000-7ffd80ca3000000 r-xp 00000000 fd:04 7523                       /usr/lib64/libxcb.so.1.1.0#0127ffd80ca3000-7ffd80ea3000 ---p 0001d000 fd:04 7523                       /usr/lib64/libxcb.so.1.1.0#0127ffd80ea3000-7ffd80ea4000 rw-p 0001d000 fd:04 7523                       /usr/lib64/libxcb.so.1.1.0#0127ffd80ea4000-7ffd80eb2000 r-xp 00000000 fd:04 13534                      /usr/lib64/libusb-1.0.so.0.1.0#0127ffd80eb2000-7ffd810b2000 ---p 0000e000 fd:04 13534                      /usr/lib64/libusb-1.0.so.0.1.0#0127ffd810b2000-7ffd810b3000 rw-p 0000e000 fd:04 13534                      /usr/lib64/libusb-1.0.so.0.1.0#0127ffd810b3000-7ffd810c0000 r-xp 00000000 fd:04 37123                      /usr/lib64/libraw1394.so.11.0.1#0127ffd810c0000-7ffd812c0000 ---p 0000d000 fd:04 37123                      /usr/lib64/libraw1394.so.11.0.1#0127ffd812c0000-7ffd812c1000 rw-p 0000d000 fd:04 37123                      /usr/lib64/libraw1394.so.11.0.1#0127ffd812c1000-7ffd812c3000 r-xp 00000000 fd:00 234                        /lib64/libkeyutils.
 .1.3
7ffd812c3000-7ffd814c2000000 ---p 00002000 fd:00 234                        /lib64/libkeyutils.so.1.3#0127ffd814c2000-7ffd814c3000 r--p 00001000 fd:00 234                        /lib64/libkeyutils.so.1.3#0127ffd814c3000-7ffd814c4000 rw-p 00002000 fd:00 234                        /lib64/libkeyutils.so.1.3#0127ffd814c4000-7ffd814ce000 r-xp 00000000 fd:00 244                        /lib64/libkrb5support.so.0.1#0127ffd814ce000-7ffd816cd000 ---p 0000a000 fd:00 244                        /lib64/libkrb5support.so.0.1#0127ffd816cd000-7ffd816ce000 r--p 00009000 fd:00 244                        /lib64/libkrb5support.so.0.1#0127ffd816ce000-7ffd816cf000 rw-p 0000a000 fd:00 244                        /lib64/libkrb5support.so.0.1#0127ffd816cf000-7ffd816e8000 r-xp 00000000 fd:04 4961                       /usr/lib64/libsasl2.so.2.0.23#0127ffd816e8000-7ffd818e7000 ---p 00019000 fd:04 4961                       /usr/lib64/libsasl2.so.2.0.23#0127ffd818e7000-7ffd818e8000 r--p 00018000 fd:04 4961                       /usr/lib64/libsasl2.so.2.0.23#0127ff
 64/libssl.so.1.0.1e
7ffd81d73000-7ffd81f73000000 ---p 00061000 fd:04 11167                      /usr/lib64/libssl.so.1.0.1e#0127ffd81f73000-7ffd81f77000 r--p 00061000 fd:04 11167                      /usr/lib64/libssl.so.1.0.1e#0127ffd81f77000-7ffd8
mmap problem?
HartyShow
Post by HartyShow »
Hi all :)
I read my history command and see I haven't copy apache configuration for centos ... :oops:
So I copied this file, modified for my configuration, but, it doesn't work (record with zoneminder work fine):
Alias /zm "/var/www/html/zm"
<Directory "/var/www/html/zm">
    Options -Indexes MultiViews FollowSymLinks
    AllowOverride All
    Order allow,deny
    Allow from all
    # The code unfortunately uses short tags in many places
    php_value short_open_tag 1
</Directory>
ScriptAlias /cgi-bin/zm "/var/www/cgi-bin"
<Directory "/var/www/cgi-bin">
    AllowOverride All
    Options ExecCGI
    Order allow,deny
    Allow from all
</Directory>
I httpd.conf, I have:
#ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
# "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
#<Directory "/var/www/cgi-bin">
#    AllowOverride None
#    Options None
#    Order allow,deny
#    Allow from all
#</Directory>
I have always this error message:
2014-09-02 14:23:35.853025	web_php	16627	ERR	socket_sendto( /tmp/zm/zms-061054s.sock ) failed: No such file or directory	zm/includes/functions.php	2337
Thx for your support :D
HartyShow
Post by HartyShow »
[Not resolve but working with Debian 7.6 and package zoneminder 1.25]
