Zoneminder 1.25X Probing Camera Info Issues
metallica1973
Post by metallica1973 »
I have setup Zoneminder 1.25X. I have a total of 7 cameras,5 Dlink DCS 3220 IP and 3 Pelco Spectra Dome Cameras. I have successfully setup the IP cameras but when it comes to setting these analog cameras I am having trouble finding the capture palette settings and etc. When I attempt to run:
zmu -d /dev/video0 -q -v
I get
Error, failed to query crop capabilities /dev/video0: Success
I can see there was a bug in 2011:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=608790
but would imagine that this has been rectified since. Can someone please guide me in determining how I can aquire the settings of the cameras so I can configure them in Zoneminder?
System info:
Ubuntu 12.04 LTS Desktop 32-bit
Zoneminder 1.25.0 (from Ubuntu repository)
Bluecherry BC-08240A - 8 port video, 8 port audio realtime hardware compression card
I can see there is a patch for slackware but what about ubuntu 12.04.
bb99
Re: Zoneminder 1.25X Probing Camera Info Issues
Post by bb99 »
Best and easiest thing to do is email bluecherry support. I believe they have a special driver that needs to be installed for the card to work properly.
metallica1973
Thanks for the reply. The issue isnt the dvr card, I have already installed the solo6010-dkm driver from bluecherry and it is working correctly
[    8.520907] solo6x10 0000:0a:09.0: Display as /dev/video0 with 8 inputs (2 extended)
[    8.524097] ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.529107] solo6x10 0000:0a:09.0: Encoders as /dev/video1-8
Here my output of:
vlc -vvv --color v4l2:///dev/video0 --run-time 1 vlc://quit -I dummy -V dummy -A dummy
VLC media player 2.0.3 Twoflower (revision 2.0.2-93-g77aa89e)
[0x97728f0] main libvlc debug: VLC media player - 2.0.3 Twoflower
[0x97728f0] main libvlc debug: Copyright © 1996-2012 VLC authors and VideoLAN
[0x97728f0] main libvlc debug: revision 2.0.2-93-g77aa89e
[0x97728f0] main libvlc debug: configured with ./configure  '--enable-static' '--build=i686-linux-gnu' 'CFLAGS=-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security' 'CPPFLAGS=-D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro' '--config-cache' '--disable-maintainer-mode' '--disable-silent-rules' '--disable-update-check' '--enable-fast-install' '--prefix=/usr' '--docdir=/usr/share/doc/vlc-nox' '--sysconfdir=/etc' '--with-binary-version=0ubuntu0.12.04.1' '--enable-a52' '--enable-aa' '--enable-bluray' '--enable-bonjour' '--enable-caca' '--enable-dbus' '--enable-dca' '--enable-dirac' '--enable-directfb' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freetype' '--enable-fribidi' '--enable-gnutls' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libproxy' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-mkv' '--enable-mod' '--enable-mpc' '--enable-mtp' '--enable-mux_ogg' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-oss' '--enable-pulse' '--enable-qt4' '--enable-realrtsp' '--enable-samplerate' '--enable-schroedinger' '--enable-sdl' '--enable-shout' '--enable-skins2' '--enable-smb' '--enable-speex' '--enable-svg' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vcd' '--enable-vcdx' '--enable-vorbis' '--enable-x264' '--enable-zvbi' '--with-kde-solid=/usr/share/kde4/apps/solid/actions/' '--disable-dxva2' '--disable-gnomevfs' '--disable-goom' '--disable-portaudio' '--disable-projectm' '--disable-sqlite' '--disable-telx' '--enable-alsa' '--enable-atmo' '--enable-dc1394' '--enable-dv' '--enable-fbosd' '--enable-libva' '--enable-linsys' '--enable-omxil' '--enable-pvr' '--enable-udev' '--enable-v4l2' '--enable-crystalhd' '--enable-mmx' '--enable-sse' '--disable-neon' '--disable-altivec' 'build_alias=i686-linux-gnu'
[0x97728f0] main libvlc debug: searching plug-in modules
[0x97728f0] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[0x97728f0] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[0x97728f0] main libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins.dat
[0x97728f0] main libvlc debug: plug-ins loaded: 420 modules
[0x97728f0] main libvlc debug: opening config file (/home/westwood/.config/vlc/vlcrc)
[0x97728f0] main libvlc debug: translation test: code is "C"
[0x97728f0] main libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 FPU
[0x97728f0] main libvlc debug: looking for memcpy module: 4 candidates
[0x97728f0] main libvlc debug: using memcpy module "memcpymmxext"
[0x980a878] main input debug: Creating an input for 'Media Library'
[0x980a878] main input debug: Input is a meta file: disabling unneeded options
[0x980a878] main input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[0x980a878] main input debug: `file/xspf-open:///home/westwood/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/home/westwood/.local/share/vlc/ml.xspf'
[0x980a878] main input debug: creating demux: access='file' demux='xspf-open' location='/home/westwood/.local/share/vlc/ml.xspf' file='/home/westwood/.local/share/vlc/ml.xspf'
[0x9808858] main demux debug: looking for access_demux module: 3 candidates
[0x9808858] main demux debug: no access_demux module matching "file" could be loaded
[0x9808858] main demux debug: TIMER module_need() : 0.801 ms - Total 0.801 ms / 1 intvls (Avg 0.801 ms)
[0x980a878] main input debug: creating access 'file' location='/home/westwood/.local/share/vlc/ml.xspf', path='/home/westwood/.local/share/vlc/ml.xspf'
[0x9793468] main access debug: looking for access module: 2 candidates
[0x9793468] filesystem access debug: opening file `/home/westwood/.local/share/vlc/ml.xspf'
[0x9793468] main access debug: using access module "filesystem"
[0x9793468] main access debug: TIMER module_need() : 0.367 ms - Total 0.367 ms / 1 intvls (Avg 0.367 ms)
[0x97943c0] main stream debug: Using stream method for AStream*
[0x97943c0] main stream debug: starting pre-buffering
[0x97943c0] main stream debug: received first data after 0 ms
[0x97943c0] main stream debug: pre-buffering done 296 bytes in 0s - 5255 KiB/s
[0x97945c0] main stream debug: looking for stream_filter module: 7 candidates
[0x97945c0] main stream debug: no stream_filter module matching "any" could be loaded
[0x97945c0] main stream debug: TIMER module_need() : 0.879 ms - Total 0.879 ms / 1 intvls (Avg 0.879 ms)
[0x97945c0] main stream debug: looking for stream_filter module: 1 candidate
[0x97945c0] main stream debug: using stream_filter module "stream_filter_record"
[0x97945c0] main stream debug: TIMER module_need() : 0.197 ms - Total 0.197 ms / 1 intvls (Avg 0.197 ms)
[0x9808f88] main demux debug: looking for demux module: 1 candidate
[0x9808f88] playlist demux debug: using XSPF playlist reader
[0x9808f88] main demux debug: using demux module "playlist"
[0x9808f88] main demux debug: TIMER module_need() : 0.319 ms - Total 0.319 ms / 1 intvls (Avg 0.319 ms)
[0x9809148] main demux meta debug: looking for meta reader module: 2 candidates
[0x9809148] lua demux meta debug: Trying Lua scripts in /home/westwood/.local/share/vlc/lua/meta/reader
[0x9809148] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[0x9809148] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[0x9809148] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[0x9809148] main demux meta debug: no meta reader module matching "any" could be loaded
[0x9809148] main demux meta debug: TIMER module_need() : 1.947 ms - Total 1.947 ms / 1 intvls (Avg 1.947 ms)
[0x980a878] main input debug: `file/xspf-open:///home/westwood/.local/share/vlc/ml.xspf' successfully opened
[0x97fe638] main xml reader debug: looking for xml reader module: 1 candidate
[0x97fe638] main xml reader debug: using xml reader module "xml"
[0x97fe638] main xml reader debug: TIMER module_need() : 0.594 ms - Total 0.594 ms / 1 intvls (Avg 0.594 ms)
[0x9808f88] playlist demux debug: parsed 0 tracks successfully
[0x980a878] main input debug: EOF reached
[0x9808f88] main demux debug: removing module "playlist"
[0x97945c0] main stream debug: removing module "stream_filter_record"
[0x9793468] main access debug: removing module "filesystem"
[0x980a878] main input debug: TIMER input launching for 'Media Library' : 5.562 ms - Total 5.562 ms / 1 intvls (Avg 5.562 ms)
[0x97943c0] main interface debug: looking for interface module: 1 candidate
[0x97943c0] main interface debug: using interface module "hotkeys"
[0x97943c0] main interface debug: TIMER module_need() : 0.245 ms - Total 0.245 ms / 1 intvls (Avg 0.245 ms)
[0x9808f88] main interface debug: looking for interface module: 1 candidate
[0x9808f88] inhibit interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[0x9808f88] main interface debug: no interface module matching "inhibit,none" could be loaded
[0x9808f88] main interface debug: TIMER module_need() : 0.277 ms - Total 0.277 ms / 1 intvls (Avg 0.277 ms)
[0x9808f88] main interface error: no suitable interface module
[0x9809e48] main playlist debug: playlist threads correctly activated
[0x9809e48] main playlist debug: adding item `quit' ( vlc://quit )
[0x9809e48] main playlist debug: rebuilding array of current - root Playlist
[0x9809e48] main playlist debug: rebuild done - 0 items, index -1
[0x9809e48] main playlist debug: adding item `v4l2:///dev/video0' ( v4l2:///dev/video0 )
[0x98f51f8] main interface debug: looking for interface module: 1 candidate
[0x98f51f8] main interface debug: no interface module matching "globalhotkeys,none" could be loaded
[0x98f51f8] main interface debug: TIMER module_need() : 0.381 ms - Total 0.381 ms / 1 intvls (Avg 0.381 ms)
[0x98f51f8] main interface error: no suitable interface module
[0x97728f0] main libvlc error: interface "globalhotkeys,none" initialization failed
[0x98f51f8] dummy interface: using the dummy interface module...
[0x98f51f8] main interface debug: using interface module "dummy"
[0x98f51f8] main interface debug: TIMER module_need() : 0.245 ms - Total 0.245 ms / 1 intvls (Avg 0.245 ms)
[0x9809e48] main playlist debug: processing request item: null, node: Playlist, skip: 0
[0x9809e48] main playlist debug: rebuild done - 2 items, index -1
[0x9809e48] main playlist debug: starting playback of the new playlist item
[0x9809e48] main playlist debug: resyncing on v4l2:///dev/video0
[0x9809e48] main playlist debug: v4l2:///dev/video0 is at 0
[0x9809e48] main playlist debug: creating new input thread
[0xb54005f0] main input debug: Creating an input for 'v4l2:///dev/video0'
[0xb5200560] main input debug: Creating an input for 'quit'
[0x9809e48] main playlist debug: no fetch required for (null) (art currently (null))
[0xb54005f0] main input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[0xb54005f0] main input debug: `v4l2:///dev/video0' gives access `v4l2' demux `' path `/dev/video0'
[0xb54005f0] main input debug: creating demux: access='v4l2' demux='' location='/dev/video0' file='/dev/video0'
[0xb5000960] main demux debug: looking for access_demux module: 1 candidate
[0xb5000960] v4l2 demux debug: opening device '/dev/video0'
[0xb5000960] v4l2 demux debug: trying kernel V4L2
[0xb5000960] v4l2 demux debug: device Softlogic 6010 using driver solo6x10 (version 2.4.3) on PCI 0000:0a:09.0
[0xb5000960] v4l2 demux debug: the device has the capabilities: 0x05000001
[0xb5000960] v4l2 demux debug:  (X) Video Capture, ( ) Audio, ( ) Tuner, ( ) Radio
[0xb5000960] v4l2 demux debug:  (X) Read/Write, (X) Streaming, ( ) Asynchronous
[0xb5000960] v4l2 demux debug: video input 0 (Camera 1) has type: External analog input *
[0xb5000960] v4l2 demux debug: video input 1 (Camera 2) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 2 (Camera 3) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 3 (Camera 4) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 4 (Camera 5) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 5 (Camera 6) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 6 (Camera 7) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 7 (Camera 8) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 8 (Multi 4UP-1) has type: External analog input
[0xb5000960] v4l2 demux debug: video input 9 (Multi 4UP-2) has type: External analog input
[0xb5000960] v4l2 demux debug: input set to 0
[0xb5000960] v4l2 demux debug: device supports chroma UYVY [UYUV 4:2:2 Packed, UYVY]
[0xb5000960] v4l2 demux debug:  boolean  Motion Detection Trace (08000002)
[0xb5000960] v4l2 demux debug:   current: false, default: false
[0xb5000960] v4l2 demux debug: found default width and height of 704x480
[0xb5000960] v4l2 demux debug: will try to find optimal width and height
[0xb5000960] v4l2 demux debug: Found maximum framerate of -1.000000
[0xb5000960] v4l2 demux warning: Could not find optimal width and height, falling back to driver default.
[0xb5000960] v4l2 demux debug: Driver requires at most 675840 bytes to store a complete image
[0xb5000960] v4l2 demux debug: Interlacing setting: interleaved (bottom top if M/NTSC, top bottom otherwise)
[0xb5000960] v4l2 demux debug: added new video es UYVY 704x480
[0xb5000960] v4l2 demux debug:  frame rate: -1.000000
[0xb54005f0] main input debug: selecting program id=0
[0xb5000960] main demux debug: using access_demux module "v4l2"
[0xb5000960] main demux debug: TIMER module_need() : 5.301 ms - Total 5.301 ms / 1 intvls (Avg 5.301 ms)
[0xb5004840] main decoder debug: looking for decoder module: 30 candidates
[0xb5004840] main decoder debug: using decoder module "rawvideo"
[0xb5004840] main decoder debug: TIMER module_need() : 15.864 ms - Total 15.864 ms / 1 intvls (Avg 15.864 ms)
[0xb5010f28] main demux meta debug: looking for meta reader module: 2 candidates
[0xb5010f28] lua demux meta debug: Trying Lua scripts in /home/westwood/.local/share/vlc/lua/meta/reader
[0xb5010f28] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[0xb5010f28] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[0xb5010f28] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[0xb5010f28] main demux meta debug: no meta reader module matching "any" could be loaded
[0xb5010f28] main demux meta debug: TIMER module_need() : 0.811 ms - Total 0.811 ms / 1 intvls (Avg 0.811 ms)
[0xb54005f0] main input debug: `v4l2:///dev/video0' successfully opened
[0xb54005f0] main input debug: Buffering 0%
[0xb5201450] main spu text debug: looking for text renderer module: 2 candidates
[0xb5201450] freetype spu text debug: Building font databases.
[0xb5201450] freetype spu text debug: Took 1 microseconds
[0xb5201450] freetype spu text debug: Using Serif Bold as font from file /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
[0xb5201450] freetype spu text debug: using fontsize: 2
[0xb5201450] main spu text debug: using text renderer module "freetype"
[0xb5201450] main spu text debug: TIMER module_need() : 5.982 ms - Total 5.982 ms / 1 intvls (Avg 5.982 ms)
[0xb52119f0] main scale debug: looking for video filter2 module: 18 candidates
[0xb52119f0] swscale scale debug: 32x32 chroma: YUVA -> 16x16 chroma: RGBA with scaling using Bicubic (good quality)
[0xb52119f0] main scale debug: using video filter2 module "swscale"
[0xb52119f0] main scale debug: TIMER module_need() : 1.583 ms - Total 1.583 ms / 1 intvls (Avg 1.583 ms)
[0xb52123b0] main scale debug: looking for video filter2 module: 18 candidates
[0xb52123b0] yuvp scale debug: YUVP to YUVA converter
[0xb52123b0] main scale debug: using video filter2 module "yuvp"
[0xb52123b0] main scale debug: TIMER module_need() : 1.356 ms - Total 1.356 ms / 1 intvls (Avg 1.356 ms)
[0xb5200560] main video output debug: Deinterlacing available
[0xb5200560] main video output debug: deinterlace 0, mode blend, is_needed 0
[0xb5200560] main video output debug: Opening vout display wrapper
[0x980b3d8] main vout display debug: looking for vout display module: 1 candidate
[0x980b3d8] main vout display debug: using vout display module "vdummy"
[0x980b3d8] main vout display debug: TIMER module_need() : 0.294 ms - Total 0.294 ms / 1 intvls (Avg 0.294 ms)
[0xb5200560] main video output debug: original format sz 704x480, of (0,0), vsz 704x480, 4cc UYVY, sar 10:11, msk r0x0 g0x0 b0x0
[0xb5201450] main spu text debug: removing module "freetype"
[0xb5201450] freetype spu text debug: Took 0 microseconds
[0xb5201450] main spu text debug: TIMER module_need() : 1.039 ms - Total 1.039 ms / 1 intvls (Avg 1.039 ms)
[0xb5004840] main decoder debug: End of video preroll
[0xb5004840] main decoder debug: Received first picture
[0x980e418] main blend debug: looking for video blending module: 1 candidate
[0x980e418] main blend debug: using video blending module "blend"
[0x980e418] main blend debug: TIMER module_need() : 0.442 ms - Total 0.442 ms / 1 intvls (Avg 0.442 ms)
[0xb5200560] main video output debug: Detected interlaced video
[0xb5200560] main video output debug: deinterlace 0, mode blend, is_needed 1
[0xb54005f0] main input debug: Buffering 11%
[0xb54005f0] main input debug: Buffering 22%
[0xb54005f0] main input debug: Buffering 33%
[0xb54005f0] main input debug: Buffering 44%
[0xb54005f0] main input debug: Buffering 55%
[0xb54005f0] main input debug: Buffering 66%
[0xb54005f0] main input debug: Buffering 77%
[0xb54005f0] main input debug: Buffering 88%
[0xb54005f0] main input debug: Stream buffering done (300 ms in 300 ms)
[0xb54005f0] main input debug: Decoder buffering done in 0 ms
[0xb54005f0] main input debug: EOF reached
[0xb54005f0] main input debug: waiting decoder fifos to empty
[0x980b3d8] main vout display debug: auto hiding mouse cursor
[0x9809e48] main playlist debug: finished input
[0xb5004840] main decoder debug: removing module "rawvideo"
[0xb5004840] main decoder debug: killing decoder fourcc `UYVY', 0 PES in FIFO
[0x9809e48] main playlist debug: saving a free vout
[0x9809e48] main playlist debug: reusing provided vout
[0xb5000960] main demux debug: removing module "v4l2"
[0xb54005f0] main input debug: Program doesn't contain anymore ES
[0x9809e48] main playlist debug: dead input
[0xb54005f0] main input debug: TIMER input launching for 'v4l2:///dev/video0' : 22.987 ms - Total 22.987 ms / 1 intvls (Avg 22.987 ms)
[0x9809e48] main playlist debug: changing item without a request (current 0/2)
[0x9809e48] main playlist debug: using item 1
[0x9809e48] main playlist debug: resyncing on quit
[0x9809e48] main playlist debug: quit is at 1
[0xb54005f0] main input debug: Creating an input for 'quit'
[0xb54005f0] main input debug: `vlc://quit' gives access `vlc' demux `' path `quit'
[0xb54005f0] main input debug: creating demux: access='vlc' demux='' location='quit' file='(null)'
[0xb5000960] idummy demux: command `quit'
[0x97728f0] main libvlc debug: exiting
[0xb5000960] main demux debug: using access_demux module "idummy"
[0xb5000960] main demux debug: TIMER module_need() : 0.404 ms - Total 0.404 ms / 1 intvls (Avg 0.404 ms)
[0x97728f0] main libvlc debug: deactivating the playlist
[0x9809e48] main playlist debug: deactivating the playlist
[0x9809e48] main playlist debug: incoming request - stopping current input
[0x9809e48] main playlist debug: dying input
[0xb5004ae0] main demux meta debug: looking for meta reader module: 2 candidates
[0xb5004ae0] lua demux meta debug: Trying Lua scripts in /home/westwood/.local/share/vlc/lua/meta/reader
[0xb5004ae0] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[0xb5004ae0] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[0xb5004ae0] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[0xb5004ae0] main demux meta debug: no meta reader module matching "any" could be loaded
[0xb5004ae0] main demux meta debug: TIMER module_need() : 0.716 ms - Total 0.716 ms / 1 intvls (Avg 0.716 ms)
[0xb54005f0] main input debug: `vlc://quit' successfully opened
[0xb5000960] main demux debug: removing module "idummy"
[0xb54005f0] main input debug: TIMER input launching for 'quit' : 1.625 ms - Total 1.625 ms / 1 intvls (Avg 1.625 ms)
[0xb5200560] main video output debug: destroying useless vout
[0x980e418] main blend debug: removing module "blend"
[0x980b3d8] main vout display debug: removing module "vdummy"
[0xb52123b0] main scale debug: removing module "yuvp"
[0xb52119f0] main scale debug: removing module "swscale"
[0x9786830] main playlist export debug: saving Media Library to file /home/westwood/.local/share/vlc/ml.xspf
[0x9786830] main playlist export debug: looking for playlist export module: 1 candidate
[0x9786830] main playlist export debug: using playlist export module "export"
[0x9786830] main playlist export debug: TIMER module_need() : 0.415 ms - Total 0.415 ms / 1 intvls (Avg 0.415 ms)
[0x9786830] main playlist export debug: removing module "export"
[0x9809e48] main playlist debug: playlist correctly deactivated
[0x97728f0] main libvlc debug: removing all services discovery tasks
[0x97728f0] main libvlc debug: removing all interfaces
[0x98f51f8] main interface debug: removing module "dummy"
[0x97943c0] main interface debug: removing module "hotkeys"
[0x9809e48] main playlist debug: destroying
[0x97728f0] main libvlc debug: TIMER ML Load : Total 6.686 ms / 1 intvls (Avg 6.686 ms)
[0x97728f0] main libvlc debug: TIMER Items array build : Total 0.182 ms / 2 intvls (Avg 0.091 ms)
[0x97728f0] main libvlc debug: TIMER Preparse run : Total 1.677 ms / 1 intvls (Avg 1.677 ms)
[0x97728f0] main libvlc debug: TIMER ML Dump : Total 0.793 ms / 1 intvls (Avg 0.793 ms)
[0x97728f0] main libvlc debug: removing stats
[0x97728f0] main libvlc debug: removing module "memcpymmxext"
The section that I found interesting:
Does the videp input 0-9 mean "device channel" or does it mean "/dev/video0-8"? Also I can see UYVY under capture palettes but have tried multiple settings without success. What gives?
bb99
Post by bb99 »
Conventional setup wisdom appears not to work on this card. After some reading I stumbled across this: http://bluecherry.zendesk.com/entries/2 ... zoneminder
Hope it at least gives you some clues.
metallica1973
I found this on the bluecherry site and have confirmed these findings ('extended' layouts) in my probing of the settings for the card/camera.
http://community.bluecherrydvr.com/resp ... sion_cards
When I run use:
vlc v4l:// :v4l-vdev="/dev/video6"
mplayer tv:// -tv driver=v4l2:width=640:height=480:device=/dev/video6 -fps 15
guvcview --device=/dev/video6
as you can see from what I posted below, I am able to see the video inputs(8,9 respectively) and the capture palette(UYVY [UYUV 4:2:2 Packed, UYVY])
That being said, how can I tell zoneminder to use the "'extended' layouts" for the card and these settings??
This shows promise.
[url]http://www.zoneminder.com/forums/viewtopic.php?f=29&t=19539&p=76736&hilit=1.25.x+patch#p76736[/url]
having trouble with the install from source:
[url]http://tom.webarts.ca/Blog/new-blog-items/buildingzoneminderandrequiredffmpegandx264fromsource[/url]
