zm 1.25.0:Views monitor: no fps, no events. ERR: $clear is..
letsharehowto
Post by letsharehowto »
Follow this: http://www.zoneminder.com/forums/viewto ... 21&t=17665, I install Zoneminder 1.25.0. It works but when I view Monitor: no number fps, no Events.
This ERR:
2011-07-01 22:30:43.644225 zma_m1 14983 INF Monitor-1: 39000 - Processing at 25.00 fps zm_monitor.cpp 1055
2011-07-01 22:30:43.552043 zmc_dvideo0 14977 INF Monitor-1: 39000 - Capturing at 25.00 fps zm_monitor.cpp 2598
2011-07-01 22:30:36.184224 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:30:24.158711 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:30:12.168559 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:30:03.678568 zma_m1 14983 INF Monitor-1: 38000 - Processing at 25.00 fps zm_monitor.cpp 1055
2011-07-01 22:30:03.583966 zmc_dvideo0 14977 INF Monitor-1: 38000 - Capturing at 25.00 fps zm_monitor.cpp 2598
2011-07-01 22:30:00.154498 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:30:00.061959 zma_m1 14983 INF Monitor-1: 37909 - Opening new event 4, section start zm_monitor.cpp 1293
2011-07-01 22:30:00.042122 zma_m1 14983 INF Monitor-1: 37909 - Closing event 3, section end zm_monitor.cpp 1273
2011-07-01 22:29:48.259644 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:29:48.196533 web_js 2307 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 547
2011-07-01 22:29:36.152176 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:29:24.149930 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:29:23.722597 zma_m1 14983 INF Monitor-1: 37000 - Processing at 25.00 fps zm_monitor.cpp 1055
2011-07-01 22:29:23.615887 zmc_dvideo0 14977 INF Monitor-1: 37000 - Capturing at 25.00 fps zm_monitor.cpp 2598
2011-07-01 22:29:12.209494 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:29:00.188247 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:28:48.192039 web_js 2290 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 112
2011-07-01 22:28:48.130780 web_js 15164 ERR $clear is not defined http://192.168.1.75/zm/skins/classic/views/js/watch.js 547
2011-07-01 22:28:43.745259 zma_m1 14983 INF Monitor-1: 36000 - Processing at 25.00 fps zm_monitor.cpp 1055
Scrip to install:
echo "options i2c-algo-bit bit_test=1" > /etc/modprobe.d/bttv.conf && echo "options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0" >> /etc/modprobe.d/bttv.conf
mount /dev/sdb1 /mnt
cp /mnt/zm/* /usr/src
cd /usr/src && tar -xzvf ZoneMinder-1.25.0-3468.tar.gz
cp /mnt/zm/sources.list /etc/apt/
umount /mnt
apt-get update && apt-get upgrade -y && apt-get install mc htop -y
#!/bin/bash
HOMEDIR=~
FFMPEG_EXTRAS=
echo "Enter MYSQL root password to use"
read -s MYSQL_ROOTPW
cd $HOMEDIR
sudo apt-get update
sudo tasksel install lamp-server
sudo apt-get install build-essential git-core checkinstall yasm texi2html libx11-dev libxfixes-dev libxvidcore-dev zlib1g-dev pkg-config -y
git clone git://git.videolan.org/x264
cd x264
./configure --enable-shared
make
sudo make install
sudo ldconfig
cd $HOMEDIR
git clone git://git.videolan.org/ffmpeg.git
cd ffmpeg/
git checkout oldabi
./configure --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-pthreads --enable-libx264 --enable-libxvid --enable-x11grab --enable-shared $FFMPEG_EXTRAS
make
sudo make install
sudo ldconfig
ffmpeg -codecs | grep 264
sudo apt-get install mysql-client libmysqlclient-dev libjpeg-dev openssl libssl-dev libdate-manip-perl libphp-serialization-perl libcache-mmap-perl libgnutls-dev -y
sudo perl -MCPAN -e "install Sys::Mmap"
cd /usr/src/ZoneMinder-1.25.0 && ./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass --with-webgroup=www-data --with-webuser=www-data --enable-mmap CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"
make
sudo make install
echo "create database zm" | mysql -u root -p$MYSQL_ROOTPW mysql
mysql -u root -p$MYSQL_ROOTPW mysql < ./db/zm_create.sql
echo "grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass'" | mysql -u root -p$MYSQL_ROOTPW zm
mysqladmin -u root -p$MYSQL_ROOTPW reload
#sudo zmpkg.pl start
cd $HOMEDIR
reboot
Please help me to fix it. Thanks.
letsharehowto
Re: zm 1.25.0:Views monitor: no fps, no events. ERR: $clear
Now it works! Admin please close this topic. So sory.
zoneminder
Site Admin
Post by zoneminder »
I suspect this was a case of files getting cached by your browser. It's worth mentioning that clearing the cache or doing a forced refresh is a good idea when installing a new version.
Phil
