Error playing events in scale (ubuntu jaunty)
Bruno von Troba
Post by Bruno von Troba »
When I'm trying to display any event in scale ZMS returns error
Feb 10 17:25:45 kotecek zms[30326]: ERR [Got signal (Floating point exception), crashing]
02/10/11 17:25:45.519080 zms[30326].INF-zm_debug.c/305 [New Debug Level = 1, New Debug Log = /var/log/zm/zm_debug.log.30326]
02/10/11 17:25:45.519181 zms[30326].DB1-zms.cpp/91 [Query: source=event&mode=jpeg&event=34066&frame=1&scale=25&rate=25&maxfps=5&user=admin&pass=[1czp1]&rand=1297355143]
02/10/11 17:25:45.519264 zms[30326].INF-zm_user.cpp/140 [Authenticated user 'admin']
02/10/11 17:25:45.520393 zms[30326].DB1-zm_monitor.cpp/1964 [Got 1 monitors]
02/10/11 17:25:45.522077 zms[30326].DB1-zm_monitor.cpp/259 [monitor purpose=0]
02/10/11 17:25:45.522092 zms[30326].DB1-zm_monitor.cpp/266 [shm.size=32737516]
02/10/11 17:25:45.522172 zms[30326].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 620x440 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
02/10/11 17:25:45.536267 zms[30326].DB1-zm_monitor.cpp/348 [Monitor Kuchnia has function 5]
02/10/11 17:25:45.536278 zms[30326].DB1-zm_monitor.cpp/349 [Monitor Kuchnia LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
02/10/11 17:25:45.536285 zms[30326].DB1-zm_monitor.cpp/350 [Monitor Kuchnia IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
02/10/11 17:25:45.536297 zms[30326].DB1-zm_monitor.cpp/2109 [Loaded monitor 1(Kuchnia), 0 zones]
02/10/11 17:25:45.536372 zms[30326].ERR-zm_signal.cpp/77 [Got signal (Floating point exception), crashing]
When watching event in ACTUAL scale everything is fine.
When changing ZM_MPEG_REPLAY_FORMAT asf rom swf error changes saying wrong JPEG library and still showing no stream
At the same time in realtime camera display or montage view everything is working fine, in any scale.
Using Ubuntu Jaunty x64 on AMD Phenom dual core and AMD 880 chipset mainboard.
Any help would be good, searched all forum for similar error.
