Can someone help me out with cascading routers
justanotherjoe
Post by justanotherjoe »
Ok so heres the deal Im trying to setup two foscam ip cams to be viewed on the web. I have a comcast modem/router with a linksys wrt54g cascaded. Ive done this on a cable modem/router with another router setup and it worked fine. Heres the specs if someone could look over them that would be great...thanks
Cable modem/router
ip 10.1.10.1
ip range 10.1.10.100 to .189
subnet 255.255.255.0
linksy with a normal cable(non crossover) going from lan to lan ports
ip 10.1.10.190
ip range .191-199
gateway 10.1.10.1
camera 1 (connected via wifi)
ip .198:2001
camera 2 (connected via wifi)
ip .199:2002
am I suppse to foward the camera ports to the second routers ip and than foward them to the cameras? I tried several methods to no avail
kingofkya
Post by kingofkya »
Do a screen shot of what you have setup on the router. Also what ports are the cameras running on 2001 or the defualt 80
