Config for IC-3010
kerlo
Config for IC-3010
Post by kerlo »
I've you have an edimax IC-3010
Can you give the config for this cam
( i've one but i don't find the config )
many thanks for your help
cordel
Post by cordel »
Might give http://ip/file.jpg a try.Else maybe:
http://ip.address/snapshot.jpg
http://ip.address/snapshot.cgi
Also have a look at: http://ic1500.wikispaces.com/
Though I would have thought it to be more useful on either our wiki or Motions, but okay. :lol:
Most of this is from this thread:
http://www.zoneminder.com/forums/viewto ... x&start=15
kerlo
Post by kerlo »
I've image in Web browser
( Firefox on linux no activeX )
with
http://camera-ip/snapshot.jpg
but in zoneminder it's a problem of shared memory
not the access of webcam in fact
Many thanks
i'm looking to Orbit AF Webcam configuration if anyone
Mny thanks again
kerlo
Post by kerlo »
Again
I've installed Zm 1.24
and want to do working my cam with this version in rtsp
i can open cam in totem
with this addresse
rtsp://192.168.0.3:554/ipcam.sdp
but i try many differents settings but i don't have any image
If someone i've found the good configuration many thanks
kerlo
Post by kerlo »
No suggestion of using my cam with rtsp ?
many thanks
UnknownX
Post by UnknownX »
Kerlo - or anyone else -,
do you got a solution for the rtsp stream of such camera ?
many thanks ...
kerlo
Post by kerlo »
Sorry i've no more news for this camera
sef1976
Post by sef1976 »
share it on inet
and i see configuration
UnknownX
Post by UnknownX »
hi@ll,
during the last hours i've set up a new and clean lenny and installed all parts as described in the the documentation of ubuntu step-by-step. Now I have a good stream with 320x240 a average of 20-25 fps which i find very good result with zm on a virtual machine :-)
nevertheless there are new questions:
first of all: is it possible to get a mpeg4 stream from the cam to zm ? I have tried the versions of snapshot.jpg/cgi and also the rtsp connection which all worked.
if it is so - until this time i know some commercial products which allow to do a motion detection with a stream of a low bandwidth/resolution and record a high quality stream only if a motion is detected.
with this feature (where i don't know if it possible in zm to combine to streams this way) the cpu usage could be hold very low.
so there are two questions:
1.) is it possible to receive a mpeg4 stream (cause of the firmware of the cam you can only set the resolution either for mjpeg or mpeg4 and as far as i know it is not possible to receive e.g. two mjpeg streams with different resolutions/quality at the same time) ?
2.) is it possible to do motion detection an a "low bandwidth" stream an do the record on another source with high quality ?
many thanks for your answers !
regards
stefan
