Storage requirements
jameswilson
Post by jameswilson »
As i cannot program I have put together a little spreadsheet (excel im afraid) that you enter pps, number of inputs capture sizes etc and it calculates the amount of days stored in record mode) now it is a simple image size x pps x inputs etc, as i dont know how zm stores images. It wont be exact but it seems accurate to me using my setups as examples. How shall i get it here, and is it any use?
James
dmit
Post by dmit »
Yes, sure! Put it somewhere please! I will create a PHP module so a user could estimate storage reqs on-line (from Zm console for example).
I think Phil could even put it on his site for more convenience for beginners!
zoneminder
Site Admin
Post by zoneminder »
By all means mail it to me James and I'll put it up in the Downloads section and add a FAQ with a link to it.
Phil
jameswilson
not sure if its being over hyped!!!
jameswilson
emailed over. I have included a small table of differnet image sizes (KB) at the relevant jpeg quality settings. At the mo i have only done 368x288 from 100 to 50 (as i cant see why ud want to go lower). I will continue to work on this to include the higher res stuff and mono (forgot to mention that its all in in 24 bit colour.)
zoneminder
Site Admin
Hi James,
I don't seem to have it yet. I wonder if my anti-spam/virus bounced it. If so then try sending it zipped up if you didn't already.
Phil
jameswilson
ok zipped and sent again
jameswilson
I have also added the high res pal now to the list of image sizes. If what i sent is any use let me know and ill send the new list
