How to scale in cycle / montage view
Hi, I would like the picture to scale and occupy the FULL SCREEN in my browser. Is there a way to do it?
Re: How to scale in cycle / montage view
try zmNinja for desktops......https://github.com/pliablepixels/zmNinja/releases
this program can scale the ZoneMinder video streams to full screen
I believe you need to install API version of ZM for this to work..Am I right? I am not sure what to answer for ZM API URL as well as PATH TO CGI BIN which is I believe http://{my zm url}/cgi-bin/nph-zms (as defined under paths)
yes it does.
if your base url is server.com/zm
your API base is most likely server.com/zm/api
your CGI path is most likely server.com/zm/cgi-bin
Please follow https://github.com/pliablepixels/zmNinj ... r-with-API
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
