crashed, signal 134
theforce
crashed, signal 134
Post by theforce »
I just replace an old foscam clone with an Axis M3203 camera and I keep getting this in the logs.
2014-09-29 13:59:01.391500 zmdc 1880 INF 'zmc -m 28' crashed, signal 134 zmdc.pl
2014-09-29 13:59:00.041170 zmdc 2401 INF 'zmc -m 28' started at 14/09/29 13:59:00 zmdc.pl
2014-09-29 13:59:00.040930 zmdc 1880 INF 'zmc -m 28' starting at 14/09/29 13:59:00, pid = 2401 zmdc.pl
2014-09-29 13:59:00.036980 zmdc 1880 INF Starting pending process, zmc -m 28 zmdc.pl
The repeats over and over again.
I get a black image with trying to view the camera and these errors.
2014-09-29 14:10:02.977472 zms 2897 WAR Unable to store frame as shared memory invalid zm_monitor.cpp 3624
2014-09-29 14:10:02.857369 zms 2897 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results zm_monitor.cpp 439
2014-09-29 14:10:41.535880 zmdc 1880 INF 'zmc -m 28' crashed, signal 134 zmdc.pl
2014-09-29 14:10:35.972120 zmdc 1880 WAR Can't find process with command of 'zma -m 28' zmdc.pl
2014-09-29 14:10:35.856090 zmdc 1880 WAR Can't find process with command of 'zmtrack.pl -m 28' zmdc.pl
2014-09-29 14:10:35.715680 zmdc 1880 INF 'zmc -m 28' starting at 14/09/29 14:10:35, pid = 2933 zmdc.pl
2014-09-29 14:10:35.715140 zmdc 2933 INF 'zmc -m 28' started at 14/09/29 14:10:35
This is on a 16 IP camera setup.
1 Axis M3204
12 Axis M3203
3 foscam PTZ clones
All is working except for my new Axis M3203.
theforce
Re: crashed, signal 134
Post by theforce »
After playing around with it apparently I cannot add another axis camera.
The maximum cameras I can have are 12 Axis cameras and the 3 PTZ foscam cones.
I disabled my Axis M3204 camera to get all of my essential cameras working. The M3204 is just a weather camera and is not needed for Zoneminder.
So I still have 2 M3203 cameras I would like to install. What is this "signal 134" and why cant I add any more cameras?
theforce
Post by theforce »
I tried doubling the shared memory and that did not help.
Does anyone know what is going on with my setup?
theforce
Post by theforce »
I have not found a solution to this issue. I'm moving on and upgrading my system.
compac
Post by compac »
already supports FFMPEG.... (just install the ffmpeg libs and set the use ffmpeg option at zm)
