Max Storage Usage Setting
kbocek
Post by kbocek »
After upgrading to 1.26.3 I can no longer find the "Use Max Storage Percentage" (or whatever it was called) setting. I set this in 1.24.2 to get ZM to flush out old events and keep my storage usage to about 98% or so.
Can anyone tell me where it's located now?
chippy99
Re: Max Storage Usage Setting
Post by chippy99 »
Click on the filters button on bottom of main screen and then select purgewhenfull filter
kbocek
Post by kbocek »
There it is. Thank you. Looks like the setting survived the upgrade. I had kept the database so I'm sure it's stored there.
The filter has an asterisk next to it. What does that mean?
whatboy
Post by whatboy »
Means it is running in the background...
kbocek
Post by kbocek »
Thank you. That makes sense.
