I cannot run ZoneMinder on Debian.
gallonin
Post by gallonin »
I installed ZoneMinder on Debian by repositorium...
#apt-get install zoneminder
... and ZoneMinder start with debian, but I do not know how run ZoneMinder. If I put my IP address into web browser I see only Apache web page.
How configure ZoneMinder to work?
PS. Sorry for my english.
mjsameth
Re: I cannot run ZoneMinder on Debian.
Post by mjsameth »
try http://ip_address/zoneminder
PacoLM
Post by PacoLM »
* Configure zoneminder:
In the file /etc/apache2/sites-enabled/000-default
Change 'DocumentRoot /var/www', to 'DocumentRoot /usr/share/zoneminder'
Change '<Directory /var/www/>', to '<Directory /usr/share/zoneminder/>'
service apache2 restart
Open the browser and put the local ip address of your computer, zm interface will appear.
Hope it helps,
PacoLM
gallonin
Post by gallonin »
mjsameth wrote:try h t t p://ip_address/zoneminder
Doesn't work.
PacoLM wrote:* Configure zoneminder:
During apache2 restart is message:
... waiting Warning: DocumentRoot [etc/share/zoneminder/] does not exist
PacoLM
Post by PacoLM »
Is the path to the zoneminder files correct?. Seems that you missed a '/' before the 'etc', but first check the files are in /etc/share/zoneminder.
PacoLM
gallonin
Post by gallonin »
PacoLM
I have problem with copy/paste between VirtualBox and Windows.
Into ...zoneminder/ folder is only index.php file and other folders.
gallonin
Post by gallonin »
PacoLM
ZoneMinder Work.
:mrgreen:
Boeboe
Post by Boeboe »
The Zoneminder apache configuration is available in /etc/zm/apache.conf
Add the lines from that file in /etc/apache2/sites-enabled/000-default between:
</Directory>
Alias /zm /usr/share/zoneminder
<Directory /usr/share/zoneminder>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
Verified on my Raspberry pi (Raspbian) system
