Compete Installation Guide
flyingscubakev
Post by flyingscubakev »
HI,
I've been looking through most of the topics and was wondering if there is a "real" installation guide that is complete? I'm trying to install the latest version on Fedora (11, 12, 13, 14 or 15) and I can't seem to find any guide that is complete. I have a couple IP cameras and a USB one, I installed a version in Fedora 9 using yum and the USB camera worked but could not get the IP cameras working. I then reloaded a newer version of Fedora and installed the 1.24 version using yum and the IP cameras work but not the USB (although I can see the usb camera in other applications).
Any specific place to look?
Thanks in advanced.
bb99
Re: Compete Installation Guide
Post by bb99 »
Did you try: http://www.zoneminder.com/wiki/index.php/Fedora, "The easy way"? Check out the Hiredguntech post for additional mods. Only gets you to 1.24.2 though.
flyingscubakev
HI,
Yep tried the install using that link, but still no luck it seems as though I'm missing something, I will have to look at the Hiredguntech post.
bb99
Post by bb99 »
The FFMPEG path post is crucial to what you're trying to do.
