Camera Probing
zoneminder
Site Admin
Camera Probing
Post by zoneminder »
If you have updated an SVN version of 1.24 today you may have noticed a new proto-feature. If you create a new monitor you will see a 'probe' link next to the 'presets' one. This generates a little popup which attempts to auto-detect any analog video devices on your system and network cameras on your LAN and suggest suitable defaults to allow quick 'one click' type configuration.
Currently it isn't hugely sophisticated and the network camera detection is limited to only those types I know about (Axis, Panasonic and ACTi) so I am looking for some help in figuring out the rest.
The initial detection is done on MAC addresses returned from an ARP query. This then suggests possible IPs to probe. I know about a few MAC ranges but need to try and figure out some more. So I would be grateful if people could post the first 3 or 4 tuples of camera MAC addresses and the results of the queries listed below. This will help me set up a more comprehensive detection system
Here's what I have at the moment, which isn't a lot
Axis
MAC - 00:40:8c
Query1 - /axis-cgi/admin/param.cgi?action=list&group=Brand
Query2 - /axis-cgi/admin/param.cgi?action=list&group=Properties.Firmware
Panasonic
MAC - 00:80:f0
Query1 - /Get?Func=Model&Kind=1 (newer firmware only?)
Query2 - /Get?Func=CameraName&Kind=1 (newer firmware only?)
ACTi
MAC - 00:0f:7c
Query1 - /cgi-bin/system?USER=Admin&PWD=123456&SYSTEM_INFO (change username and password as appropriate)
If anyone can help put some more flesh on these bones I would be very grateful. In the meantime have a play with the probe facility and see if it works for you.
Phil
newvisionantenna
Post by newvisionantenna »
This could be huge with my wireless mesh cctv system. I'll try and help out in anyway possible.
Last edited by newvisionantenna on Sun Apr 05, 2009 7:27 pm, edited 1 time in total.
zoneminder
Site Admin
If you have any cameras at all and know a good way to detect them then that will be useful, I don't, for instance, have any recent USB cameras so I don't know what they return if you run zmu --device --query against them. Maybe they play ball, maybe not. So at the very least try the latest zmu and see what you get.
Phil
caprio
ACTi ACM3511 Mac
Post by caprio »
I think you already have this but heres the system info on my ACTi ACM-3511
Firmware Version = A1D-220-V3.09.14-AC
MAC Address = 00:0F:7C:02:3C:CF
Production ID = ACM3511-08L-X-00005
Factory Default Type = Two Ways Audio (0x71)
Company Name = ACTi Corporation
WEB Site = www.acti.com
Profile ID = MT9M131-RB2_V080825A
netnoggin
Post by netnoggin »
The vendor-to-MAC question could be answered by a site like this:
http://www.coffer.com/mac_find/
It might help you get started anyway; I use it from time to time.
Brian
cordel
Post by cordel »
We need the MAC address in correlation with the working path string folks. We already know about the IEEE and comments are not going to get us anywhere.
Thanks.
netnoggin
Post by netnoggin »
Sorry, I misinterpreted your request. I saw this
but the rest didn't sink in. Pre-coffee...
cordel
Post by cordel »
netnoggin wrote:but the rest didn't sink in. Pre-coffee...
Frequently have that issue my self. :lol:
I have a list started and will get it up shortly.
kylejohnson
Vivotek IP7131
Post by kylejohnson »
MAC: 00:02:D1:06:1B
Want any other info?
micah67
Post by micah67 »
Not that we have it working, yet, but:
MAC Address = 00:0F:7C:01:DE:58
Production ID = ACM4200-08H-X-00028
Profile ID = MT9M131-RA0_V080507A
~micah
cordel
Post by cordel »
Not to be a Debbie Downer but, the information does us no good unless we have a working configuration to go with the Manufacture, model, MAC, etc..
maikdema
My Network Cameras
Post by maikdema »
Panasonic BL-C1 Network Camera
MAC: 00-80-f0-59-76-XX
To get Jpg image: http://<IP>/SnapshotJPEG?Resolution=640x480&Quality=Precision
http://<IP>/Get?Func=Model&Kind=1
returns:
ModelName:BL-C1
BootFirm:V1.32
AplFirm:1.32
Cgii/fVer:1.06
ModelType:8220000002010000
Function:0001000000
UserAgent:Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.2; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
AXIS 210
00-40-8c-88-41-XX
http://<IP>/axis-cgi/admin/param.cgi?action=list&group=Brand
http://<IP>/axis-cgi/admin/param.cgi?action=list&group=Properties.Firmware
root.Brand.Brand=AXIS
root.Brand.ProdFullName=AXIS 210 Network Camera
root.Brand.ProdShortName=AXIS 210
root.Brand.ProdNbr=210
root.Brand.ProdType=Network Camera
root.Brand.WebURL=http://www.axis.com/
root.Properties.Firmware.BuildNumber=9
root.Properties.Firmware.BuildDate=Dec 22 2006 09:39
root.Properties.Firmware.Version=4.40
AXIS 216FD
00-40-8c-95-0d-XX
root.Brand.ProdFullName=AXIS 216FD Network Fixed Dome Camera
root.Brand.ProdShortName=AXIS 216FD
root.Brand.ProdNbr=216FD
root.Properties.Firmware.BuildNumber=2
root.Properties.Firmware.BuildDate=Apr 16 2007 13:13
root.Properties.Firmware.Version=4.40.1
belanger
PANASONIC WV-...
Post by belanger »
MODEL: WV-NF302
MAC : 00:80:45
JPEG: http://ip_addr/cgi-bin/camera
RTSP : rtsp://ip_addr/MediaInput/mpeg4
Note: its not possible to enable RTSP from the web interface. To enable RTSP send the following HTTP request :
http://ip_addr/cgi-bin/set_rtsp?rtsp_mode=1&rtsp_port=554
belanger
Re: PANASONIC WV-...
Post by belanger »
belanger wrote:MODEL: WV-NF302
MAC : 00:80:45
I should add the following note ... I tried the RTSP mode with the camera and zoneminder 1.24.1 and can't make it work -- I already posted a msg in the 1.24.1 forum regarding this issue.
coke
Post by coke »
The presets for the Axis cameras are the way to go. Choose your preset, then insert the IP in the source tab, and you should be good to go.
