Possible bug - rtp - can't set username and password
It appears the username and password "Admin" "123456" is hard coded and thus you are unable to define the real settings when using RTP with 1.24.
Tom
Tom
- zoneminder
- Site Admin
- Contact:
An ACTi camera is available here:newvisionantenna wrote:Anyone have one of these newer RTSP devices I could try on a demo I've put together? I don't have one at the moment and would like to try it out even with the password bug which I'm sure I can update down the road.
** Edit: Camera offline for now...PM if you need a demo. **
The bitrate is set low and the QoS is also pretty high as not to piss off our fiber carrier's uplink.
Big time cpu difference in trying your camera out with mpeg4 and some of the others I've tested. I've got yours up and running steady now, just throttled back on the fps. I notice that the feed from the orbit running at 960x720 is killer on the cpu compared to the ACTI. I'm sure it's just the resolution cause the picture was just amazing. I think I caught a quick glimpse of you guys inside that room ![Smile :)](./images/smilies/icon_smile.gif)
I believe the camera you were looking at was the ACM-3001...it's in our shipping center in the back part of our office.newvisionantenna wrote:Thanks, works on my DVD build and the VPS demo like a champ. Is that the inside or your shop or something? Picture quality looks amazing, probably alittle to much for all these camera's I'm messing with.
We'll I did get picture, now I'm messing with it to see what's up.
ACTi has good stuff and good picture quality
- zoneminder
- Site Admin
- Contact:
It appears that my RTSP authentication patch has not in fact gone into ffmpeg as you. I will post it up in case anyone wants to use cams with authentication that is different than the ACTi default.zoneminder wrote:Yikes! That slipped by. That's the problem with only having ACTi cams to try out.
Fixed now but I can't find the patch I submitted to ffmpeg so no username/passwords will work properly at present until I track down where it has gone.
Phil
- zoneminder
- Site Admin
- Contact:
I have problem with the authentication too. I have AVI201 camera. My parameters:
Remote Protocol : RTSP
Remote Method : RTP/RTSP
Remote Host Name : admin:admin@192.168.1.10
Remote Host Port : 554
Remote Host Path : /live/mpeg4
Remote Host SubPath
Connecting with QuickTime player is ok, but I have to type admin/admin in the popup box. \
With ZoneMinder I get everytime:
Where could be a problem ?
Remote Host SubPath
Mar 14 17:11:14 camera1 zmc_m1[13862]: INF [Starting Capture]
Mar 14 17:11:14 camera1 zmc_m1[13862]: ERR [Unable to open input 'rtsp://admin:admin@192.168.1.10:554']
Mar 14 17:11:19 camera1 zmc_m1[13862]: FAT [No RTSP sources]
Mar 14 17:11:19 camera1 zmc_m1[13862]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Mar 14 17:11:19 camera1 zmc_m1[13862]: ERR [Signal address is (nil), from 0xb7f8f424]
M
