Zones 103.14% - ??
robi
Zones 103.14% - ??
Post by robi »
Hi!
I defined some zones for my camera, and got this:
Id 	Name 	Type 		Area (px/%)
4. 	All 	Active 		114069 / 103.14
8. 	Precl1 	Preclusive 	451 / 0.41
10. 	Precl2 	Preclusive 	357 / 0.32
Is 103.14% of the area normal?
The All area is definitely smaller than the full image.
v1.25.0 + Ubuntu Linux 12.04 Server
jamescollings
Post by jamescollings »
Curious... could you post the details of that zone? (X Y values)
robi
Post by robi »
Here you go:
jamescollings
Hmm wierd!
The only things that i'd point out (not that these are the cause of your problem).
There is no need to exclude the Clock from your zone. The time is added AFTER the image comparison is done.
You can enter EXACT values into the X/Y coordinate boxes (this means that you have more accuracy than the click/drag mouse option.
I would be inclined to create your irregular shape using many zones of regular RECTANGLES. This might be more of a hassle (your current single zone would become 4 zones, but it would simplify tracking down this issue (if it still exists once you use rectangles).
Hope this helps?
