Linked Monitor is not triggered
Detlef Paschke
Post by Detlef Paschke »
I was a bit surprised that I haven't had any recordings in the last few days. Now I discovered the cause after I allowed the SD stream to record at the event.
The SD stream registers an event, but the linked HD stream does not trigger recording.
I believe the problem persists since this update:
2024-04-16 10:12:43 upgrade zoneminder:amd64 1.37.55~20240315.181-bookworm 1.37.59~20240415.28-bookworm
Many greetings
Detlef Paschke
Detlef Paschke
Re: Linked Monitor is not triggered
After resetting to a previous backup, optimizing and checking the database and then bringing ZM back to the current version, everything seems to be working again.
Another kind of self-healing that you don't know why or why.
Many greetings
Detlef Paschke
IgorA100
Post by IgorA100 »
If you understood the reason, you could try to eliminate it.
