Ubuntu release 24.04 noble is in beta release, and will likely be released as a final release in the following weeks. I have done some beta testing from the 22.04 jammy ppa and it seems to work with zoneminder 1.36 installed into Ubuntu 24.04 beta. We will need a ppa set up for zoneminder 1.36 to handle 24.04 noble. Thanks for your help.
Jeff
Ubuntu 24.04 noble release
Re: Ubuntu 24.04 noble release
Ubuntu 24.04 has been released. I'm still getting an error that there is no ppa for 1.36 noble. I do see there is a package built for 1.37.59 noble. Should I move from 1.36 to 1.37 or will there be a 1.36 noble eventually? Thanks.
1.36.X should be included in the 24.04 release. However, it likely will require special setup instructions as installing Zoneminder from the Ubuntu repositories may not set up the database.
I will look into this as time permits. Am a busy retired guy after all...
