16CH 120fps Live / 120fps "blues screens"
Hogface
Post by Hogface »
I only get blue screens.
One USB camera works fine.
Read all the post, think i've done what has been recommended
computer only has one card in it.
Could really use the help! Thanks!
/dev
Has video0-4 (5 files)
All setup on channel 0
All setup as PAL and tried NTSC
All setup as RGB24
Using a video camera as a source of video
Bought the card:
ebay #5818394403 - NEW 16CH 120fps Live / 120fps Record DVR Card - $79
modprobe.conf
alias eth0 sis900
options snd-trident index=0
remove snd-trident { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-trident
alias usb-controller ohci-hcd
alias usb-controller1 ehci-hcd
#bttv
options bttv card=77,77,77,77,77,77,77,77 radio=-1
options tuner type=4,4,4,4,4,4,4,4
alias char-major-81 bttv
lspci -vv returns:
02:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap+ 66Mhz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR>TAbort- <TAbort- <MAbort>SERR- <PERR> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 11, latency: 32, mmio: 0xe0100000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00feffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: registered device radio0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:02:0d.0[A] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 5, latency: 32, mmio: 0xe0102000
bttv1: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 7
PCI: setting IRQ 7 as level-triggered
ACPI: PCI Interrupt 0000:02:0e.0[A] -> Link [LNKA] -> GSI 7 (level, low) -> IRQ 7
bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 7, latency: 32, mmio: 0xe0104000
bttv2: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv2: gpio: en=00000000, out=00000000 in=00feffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
PCI: setting IRQ 10 as level-triggered
ACPI: PCI Interrupt 0000:02:0f.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10
bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 10, latency: 32, mmio: 0xe0106000
bttv3: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv3: gpio: en=00000000, out=00000000 in=00feffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:02:0c.1[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
bt878(0): Bt878 (rev 17) at 02:0c.1, irq: 11, latency: 32, memory: 0xe0101000
bt878: Bt878 AUDIO function found (1).
ACPI: PCI Interrupt 0000:02:0d.1[A] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
bt878(1): Bt878 (rev 17) at 02:0d.1, irq: 5, latency: 32, memory: 0xe0103000
bt878: Bt878 AUDIO function found (2).
________
og kush marijuana strain
cordel
Post by cordel »
Unless you cut the dmesg short it only shows that the card has four bt878 chips. Your config is set up for eight.
Also what error messages are you getting from zm?
What distro is this on?
What version of ZM are you using?
Regards,
Cordel
electron
Post by electron »
Can you get video using tvtime or xawtv apps ? If they can't get video from /dev/video0 or 1,2 etc.... you maybe have wrong driver loaded or something else not ZM is keeping the video not working.
Hogface
Post by Hogface »
It's supposed to be a 16 channel
It has 4 chips on it and came with 4 bnc on the back plane
and 3 add on (each with 4 bnc).
For testing, I am only trying on port, and its on the main board plane.
Zone Minder Version 1.21.3
Fedora Core 4
Yes, it was abbreviated on dmesg
Here is the full file:
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 8 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:01:00.0
PCI: Bridge: 0000:00:02.0
IO window: d000-dfff
MEM window: e0000000-e00fffff
PREFETCH window: d8000000-dfffffff
PCI: Bridge: 0000:00:0b.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: e0100000-e01fffff
PCI: Setting latency timer of device 0000:00:02.0 to 64
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1130193076.140:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key 54AD4C348BA3456
- User ID: Red Hat, Inc. (Kernel Module GPG key)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
ACPI: Fan [FAN] (on)
ACPI: CPU0 (power states: C1[C1])
ACPI: Thermal Zone [THRM] (40 C)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected SiS 730 chipset
agpgart: AGP aperture is 128M @ 0xd0000000
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 32 ports, IRQ sharing enabled
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
SIS5513: IDE controller at PCI slot 0000:00:00.1
SIS5513: chipset revision 208
SIS5513: not 100% native mode: will probe irqs later
SIS5513: SiS730 ATA 100 (1st gen) controller
ide0: BM-DMA at 0x4000-0x4007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0x4008-0x400f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: Maxtor 6L120P0, ATA DISK drive
hdb: Maxtor 31536U2, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: LG CD-ROM CRD-8521B, ATAPI CD/DVD-ROM drive
hdd: SAMSUNG SV0643D, ATA DISK drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 240121728 sectors (122942 MB) w/8192KiB Cache, CHS=65535/16/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2
hdb: max request size: 128KiB
hdb: 30015216 sectors (15367 MB) w/512KiB Cache, CHS=29777/16/63, UDMA(66)
hdb: cache flushes not supported
hdb: hdb1
hdd: max request size: 128KiB
hdd: 12594960 sectors (6448 MB) w/480KiB Cache, CHS=13328/15/63, UDMA(33)
hdd: cache flushes not supported
hdd: hdd1
hdc: ATAPI 52X CD-ROM drive, 128kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
md: md driver 0.90.2 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 3.38
NET: Registered protocol family 2
input: AT Translated Set 2 keyboard on isa0060/serio0
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 6, 458752 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
TCP bic registered
Initializing IPsec netlink socket
NET: Registered protocol family 1
NET: Registered protocol family 17
Using IPI Shortcut mode
ACPI wakeup devices:
PWRB FUTS PCI0 USB0 USB1 MAC0 AUD0 AMR0 PS2M PS2K
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 176k freed
device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
cdrom: open failed.
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
floppy0: no floppy controllers found
sis900.c: v1.08.08 Jan. 22 2005
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:01.1[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
0000:00:01.1: VIA 6103 PHY transceiver found at address 1.
0000:00:01.1: Using transceiver found at address 1 as default
eth0: SiS 900 PCI Fast Ethernet at 0xe000, IRQ 11, 00:0a:e6:66:23:02.
shpchp: acpi_shpchprm:\_SB_.PCI0 evaluate _BBN fail=0x5
shpchp: acpi_shpchprm:get_device PCI ROOT HID fail=0x5
Linux video capture interface: v1.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:02:0c.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
tveeprom(bttv internal): Huh, no eeprom present (err=-121)?
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv1: i2c: checking for MSP34xx @ 0x80... not found
bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv2: i2c: checking for MSP34xx @ 0x80... not found
bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv3: i2c: checking for MSP34xx @ 0x80... not found
ACPI: PCI Interrupt 0000:02:0e.1[A] -> Link [LNKA] -> GSI 7 (level, low) -> IRQ 7
bt878(2): Bt878 (rev 17) at 02:0e.1, irq: 7, latency: 32, memory: 0xe0105000
bt878: Bt878 AUDIO function found (3).
ACPI: PCI Interrupt 0000:02:0f.1[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10
bt878(3): Bt878 (rev 17) at 02:0f.1, irq: 10, latency: 32, memory: 0xe0107000
ACPI: PCI Interrupt 0000:00:09.2[C] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
ehci_hcd 0000:00:09.2: EHCI Host Controller
ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:09.2: irq 5, io mem 0xe0224000
ehci_hcd 0000:00:09.2: park 0
ehci_hcd 0000:00:09.2: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 5 ports detected
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10
ohci_hcd 0000:00:09.0: OHCI Host Controller
ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:09.0: irq 10, io mem 0xe0222000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
ACPI: PCI Interrupt 0000:00:09.1 -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ohci_hcd 0000:00:09.1: OHCI Host Controller
ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:09.1: irq 11, io mem 0xe0223000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 2-3: new full speed USB device using ohci_hcd and address 2
/root/sp/spca5xx-20051001/drivers/usb/spca5xx.c: USB SPCA5XX camera found. Type Creative Live! Zc301+Tas5130c
/root/sp/spca5xx-20051001/drivers/usb/spca5xx.c: [spca5xx_probe:8764] Camera type JPEG
/root/sp/spca5xx-20051001/drivers/usb/zc3xx.h: [zcxx_probeSensor:108] sensor answer1 0
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
ACPI: Sleep Button (CM) [FUTS]
ibm_acpi: ec object not found
/root/sp/spca5xx-20051001/drivers/usb/zc3xx.h: [zcxx_probeSensor:160] sensor answervga 0
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
cdrom: open failed.
/root/sp/spca5xx-20051001/drivers/usb/zc3xx.h: [zc3xx_config:414] Find Sensor HV7131(c)
/root/sp/spca5xx-20051001/drivers/usb/spca5xx.c: [spca5xx_getcapability:2528] maxw 640 maxh 480 minw 176 minh 144
usbcore: registered new driver spca5xx
/root/sp/spca5xx-20051001/drivers/usb/spca5xx.c: spca5xx driver 00.57.03 registered
EXT3 FS on dm-0, internal journal
EXT3 FS on hda1, internal journal
EXT3 FS on hdb1, internal journal
EXT3 FS on hdd1, internal journal
Adding 262136k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1
eth0: Media Link On 100mbps full-duplex
NET: Registered protocol family 10
Disabled Privacy Extensions on device c0475600(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: recovery directory /var/lib/nfs/v4recovery doesn't exist
NFSD: starting 90-second grace period
________
GE Honda Aero Engines history
cordel
Post by cordel »
Your best start is as electron had sugested. check and see if you can get video in xawetv or tvtime first. With four chips you should only need four sets of card id's for 77 in your modprobe config. This is a cheat as ideally there should only be one card number for each card.
Also are there any errors in the zm logs?
Regards,
Cordel
Hogface
Post by Hogface »
Ok changed modprobe.conf to:
options bttv card=77,77,77,77, radio=-1 tuner=4
Checked all logs:
-rw-r--r-- 1 apache apache 1200 Oct 25 19:31 zmaudit.log
-rw-r--r-- 1 apache apache 641 Oct 25 19:31 zmdc.log
srwxr-xr-x 1 apache apache 0 Oct 25 19:30 zmdc.sock
-rw-r--r-- 1 apache apache 68 Oct 25 19:31 zmfilter.log
-rw-r--r-- 1 apache apache 810 Oct 25 19:31 zmpkg.log
-rw-r--r-- 1 apache apache 86 Oct 25 19:31 zmupdate.log
-rw-r--r-- 1 apache apache 142 Oct 25 19:31 zmwatch.log
d0 is one the new video card ports
d4 is the usb which working.
Var/log has the following:
Oct 25 19:31:31 madie zmc_d0[3389]: INF [New: 1000 - Capturing at 29.41 fps]
Oct 25 19:32:04 madie zmc_d0[3389]: INF [New: 2000 - Capturing at 30.30 fps]
Oct 25 19:32:37 madie zmc_d0[3389]: INF [New: 3000 - Capturing at 30.30 fps]
Oct 25 19:33:11 madie zmc_d0[3389]: INF [New: 4000 - Capturing at 29.41 fps]
Oct 25 19:33:44 madie zmc_d0[3389]: INF [New: 5000 - Capturing at 30.30 fps]
Oct 25 19:34:18 madie zmc_d0[3389]: INF [New: 6000 - Capturing at 29.41 fps]
Oct 25 19:34:51 madie zmc_d0[3389]: INF [New: 7000 - Capturing at 30.30 fps]
Oct 25 19:35:05 madie zmc_d4[3384]: INF [USB: 1000 - Capturing at 4.03 fps]
Oct 25 19:35:24 madie zmc_d0[3389]: INF [New: 8000 - Capturing at 30.30 fps]
Not running X, can I still use these for testing?
________
medical marijuana
cordel
Post by cordel »
Are there any errors in your zmdc.log, or zmpkg.log?
Hogface
Post by Hogface »
Well good advice, there was nothing there but when I started trying again I got the following:
zmdc.log:
Can't find process with command of 'zmtrack.pl -m 25'
Can't find process with command of 'zma -m 25'
Can't find process with command of 'zmc -d 3'
Can't find process with command of 'zmtrack.pl -m 26'
Can't find process with command of 'zma -m 26'
'zmc -d 3' starting at 05/10/25 19:49:05, pid = 3750
'zmc -d 3' started at 05/10/25 19:49:05
e
zmpkg.log
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmfix'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl status'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmc -d 4'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmc -d 0'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmfilter.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmwatch.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmupdate.pl -c'
________
Ford C170 platform
Hogface
Post by Hogface »
I restarted the application and cleared the logs.
I still get blue screen, but here is zmdc.log:
'zmc -d 3' started at 05/10/25 20:02:02
'zmc -d 3' starting at 05/10/25 20:02:02, pid = 4007
'zmfilter.pl' starting at 05/10/25 20:02:03, pid = 4014
'zmfilter.pl' started at 05/10/25 20:02:03
'zmaudit.pl -d 900 -y' started at 05/10/25 20:02:05
'zmaudit.pl -d 900 -y' starting at 05/10/25 20:02:05, pid = 4020
'zmwatch.pl' started at 05/10/25 20:02:08
'zmwatch.pl' starting at 05/10/25 20:02:08, pid = 4026
'zmupdate.pl -c' started at 05/10/25 20:02:09
'zmupdate.pl -c' starting at 05/10/25 20:02:09, pid = 4031
________
iolite review
Hogface
Post by Hogface »
If I try to get a picture on dev/video0 then I get the following in the
zmdc.log:
Can't find process with command of 'zmc -d 0'
'zmc -d 0' started at 05/10/25 20:05:18
'zmc -d 0' starting at 05/10/25 20:05:18, pid = 4104
________
Lamborghini LM004
cordel
Post by cordel »
Okay, your second dmesg post shows that the card is not getting the insmod options. Try removing that last comma.
Also be aware that I don't know if that card number will work with your card.
Try clearing up your insmod option first so that it takes.
Your best bet is if you don't know what options you need to set, install with X and xawe or tvtime and get the card functional first. Then you can remove them or set to run level 3 after you know you have the card functioning.
Hogface
Post by Hogface »
I don't know that I fully understand
"insmod option". need a little guidance.
The computer is in a remote location so hard to do until the weekend for x.
I'll try w3cam/vidcat.
________
DR platform
cordel
Post by cordel »
In modprobe.conf
options bttv card=77,77,77,77 tuner=4
That is an insmod option. You have an extra comma in what you posted above so you might want to check it.
Regards,
Cordel
Hogface
Post by Hogface »
Ok, I tested outside of ZM and got blue screens on both.
Just made the change to the modprobe.conf.
The extra comma came from my earlier delete of the extra 77.
Have rebooted will try again in just a few.
________
XR80
Hogface
Post by Hogface »
Still no video from the board.
Using vidcat (w3cam) and scanning all /dev/video devices on inputs tv, comp1, comp2 to validate/compare to zm
All I get is the blue screens on 0-3
I do still get the input signal from the USB camera on video4
#/bin/sh
for INPUT in tv comp1 comp2
do
for COUNT in 0 1 2 3 4
do
echo "Working on $INPUT on Device $COUNT"
/tempweb/w3cam-0.7.2/vidcat -p c -d /dev/video$COUNT -f jpeg -i $INPUT -n ntsc -o /tempweb/w3cam-0.7.2/test$COUNT.$INPUT.jpg -q 100 -s 640x480
done
done
YEILDS the following:
(the 5k files are blue screens,
the 24k files are from the USB cam)
-rw-r--r-- 1 root root 5432 Oct 25 21:30 test0.comp1.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test0.comp2.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:30 test0.tv.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test1.comp1.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test1.comp2.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:30 test1.tv.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test2.comp1.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test2.comp2.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:30 test2.tv.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test3.comp1.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:31 test3.comp2.jpg
-rw-r--r-- 1 root root 5432 Oct 25 21:30 test3.tv.jpg
-rw-r--r-- 1 root root 24357 Oct 25 21:31 test4.comp1.jpg
-rw-r--r-- 1 root root 24819 Oct 25 21:31 test4.comp2.jpg
-rw-r--r-- 1 root root 24614 Oct 25 21:30 test4.tv.jpg
________
no2 vaporizer
