Control monitor function from CLI
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
unicon
Post by unicon »
I'm looking for a way to change a monitor function (None, Modect, Monitor ....) from the command line.
I found the Start/Stop method, but stopping a monitor switches the monitor completely off. I want to toggle the function from Modect to Monitor, depending on an external event.
Any ideas?
Re: Control monitor function from CLI
Have a look at zmu and see if that behaves in the way you want.
unicon
Post by unicon »
Thanx for the hint!
It's working a bit different from what I had in mind, but in the end it does what I finally was looking for - enabling/disabling alarms with an external trigger :D
