11/16/22, 8:01:04 PM PST web_js 2428 ERR getCmdResponse stream error: Socket /run/zm/zms-515431s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors() ?view=event&eid=261&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=11&filter%5BQuery%5D%5Bsort_asc%5D=1&filter%5BQuery%5D%5Bsort_field%5D=Name&filter%5BQ -
11/16/22, 8:01:04 PM PST web_php 2428 ERR Socket /run/zm/zms-515431s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 1882
11/16/22, 8:01:02 PM PST web_js 2537 ERR TypeError: bottomEl.offset() is undefined zm/cache/skins_classic_js_skin-base-1668613474.js 590
When I was viewing the events I clicked on the first one and then deleted it. It did not move to the next on in the list. I need to click the back arrow and then click the new "top" event.
11/16/22, 8:01:02 PM PST web_php 2428 ERR Unable to load ZM\Event record for Id=261 /usr/share/zoneminder/www/includes/Object.php 21
Not sure if these were cause before the upgrade to version 1.36.32 (I was at 1.36.31)
11/16/22, 8:00:54 PM PST web_php 1168 ERR actions can no longer be performed without POST. /usr/share/zoneminder/www/index.php 200
11/16/22, 8:00:19 PM PST web_php 2286 ERR actions can no longer be performed without POST. /usr/share/zoneminder/www/index.php 200
v1.36.32 - log errors
Re: v1.36.32 - log errors
Thanks for running my proposed ppa!
When did you last update? I have pushed a bunch more fixes today, please update and see if it is fixed. I just tried myself and deleting works fine and moves on to the next event, so I'm hoping I already fixed it.
