Does anyone know how to set a static IP on Foscam cams? If you run MS they have a EXE to do it (so they say). I'm a Nix snob and ...
Foscam setting static IP
Re: Foscam setting static IP
You can probably make it stick from your router.
Something like bypass or fixed dhcp
