Good evening from France.
Today I've broke the software zoneminder by trying to reset the event ID with a mysql command from that guide: viewtopic.php?t=13674
The first time it work but the second time my software got broken I belive because I forget to turn off zoneminder.
The symptoms are simple my camera doesn't change there state to alarm even if I force the alarm. I check the log but they told me nothing about that I check the mysql database every table are in order expect the event s who got nothing. The event count doesn't reset even if the event are removed from the web page of zoneminder I had to use zmaudit to make a reset
My software is a Debian 10 only in prompt.
I use postfix apache and of course mysql
When I want to check the content of the event table it's empty but I suppose this is normal.
I already try every form of reboot and reset.
So I was wondering if there is anything I could do to fix zoneminder or if I can something to regenerate the mysql properly. Anything that could repair it.
Thank in advance for your help.
Zoneminder alarm and mysqldatabase broken
Re: Zoneminder alarm and mysqldatabase broken
You could follow this to recreate the empty DB viewtopic.php?f=42&t=30452
Thank you I give it a try tomorrow
I will tell you if anything change
Best regard
Best regard
Thank you it work fine.
