----------- Configured Values ----------------------------
Your webserver user seems to be www-data
Your webserver group seems to be www-data
wget is /usr/bin/wget
installer software is /usr/bin/apt-get
Install Event Server: prompt
Install Event Server config: prompt
Install Hooks: prompt
Install Hooks config: prompt
Download and install models (if needed): yes
The Event Server will be installed to /usr/bin
The Event Server config will be installed to /etc/zm
Hooks will be installed to /var/lib/zmeventnotification sub-folders
Hook config files will be installed to /etc/zm
Models that will be checked/installed:
(Note, if you have already downloaded a model, it will not be deleted)
Yolo V3 (INSTALL_YOLOV3): no
TinyYolo V3 (INSTALL_TINYYOLOV3): no
Yolo V4 (INSTALL_YOLOV4): no
Tiny Yolo V4 (INSTALL_TINYYOLOV4): no
Google Coral Edge TPU (INSTALL_CORAL_EDGETPU): no
If any of this looks wrong, please hit Ctrl+C and edit the variables in this script...
Install Event Server [y/N]:y
*** Installing ES ***
Success:Completed, but you will still have to install ES dependencies as per https://zmeventnotification.readthedocs.io/en/latest/guides/install.html#install-dependencies
Install Event Server Config [y/N]:y
Replacing ES config & rules file
Success:config copied
Replacing ES rules file
Success:rules copied
====> Remember to fill in the right values in the config files, or your system won't work! <=============
Install Hook [y/N]:N
Skipping Hook install
Install Hook Config [y/N]:N
Skipping Hook config install
Creating a migrated objectconfig if required
Current version of file is unknown
Migrating from unknown to 1.0
Doing a sanity check, cpu_max_lock_wait should not be there...
There is an error in your config. While upgrading to version:1.0
I found a key (cpu_max_lock_wait) that should not have been there.
This usually means when you last upgraded, your version attribute
was not upgraded for some reason. To be safe, this script will not
upgrade the script till you fix the potential issues
*** Please remember to start the Event Server after this update ***
WARNING:THIS IS A BREAKING CHANGE RELEASE. THINGS WILL NOT WORK TILL YOU FOLLOW https://zmeventnotification.readthedocs.io/en/latest/guides/breaking.html#version-5-16-0-onwards
