I'm trying to get zmNinja to integrate into ZM but /zm/api/host/monitors.json fails (when executing it from Chrome). The error I receive is:
{"success":false,"data":{"name":"Not Found","message":"Not Found","url":"\/zm\/api\/host\/monitors.json","exception":{"class":"MissingActionException","code":404,"message":"Action HostController::monitors() could not be found."}}}
/zm/api/host/getVersion.json works fine by returning:
{"version":"1.34.20","apiversion":"2.0"}
Any guidance will be appreciated.
/zm/api/host/monitors.json doesn't return monitors
- knight-of-ni
Re: /zm/api/host/monitors.json doesn't return monitors
Referring to the documentation:
https://zoneminder.readthedocs.io/en/st ... all-events
The correct url is: http://server/zm/api/monitors.json
Thx for the prompt response and correcting the url I was testing. I unfortunately still have an issue though. This is the error i'm receiving.
{"name":"An Internal Error Has Occurred.","message":"An Internal Error Has Occurred.","url":"\/zm\/api\/monitors.json"}
I'm a noob to ZM so rather lost to which logs would be relevant to include to get help with-out wasting people's time.
- knight-of-ni
Internal error message sounds like http 500, so check your web server logs for clues.
knight-of-ni, you are correct. I found the following in the web server logs.
[17/Sep/2020:11:37:31 +0200] "GET /zm/api/monitors.json HTTP/1.1" 500 313 "-" "curl/7.58.0"
