What is causing all these errors? ZM 1.35.4
Date/Time
Component Server PID Level Message File Line
2020-05-29 22:04:20 web_php 1387 ERR socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 22:04:20 web_js 1387 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 22:04:19 web_php 1387 ERR socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 22:04:19 web_js 1387 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 22:04:14 web_php 1613 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 22:04:14 web_js 1613 ERR getCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=event
2020-05-29 22:04:14 web_php 1387 ERR socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 22:04:14 web_js 1387 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-093748s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 11: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x5653f172b59a] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2020-05-29 22:04:13 zms_e17 12132 ERR Signal address is 0x7f9c05803038, from 0x7f9c00a2698d zm_signal.cpp 83
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5653f17c27c8] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f9c04a61890] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x3d) [0x7f9c00a2698d] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(+0x43041) [0x7f9c009d2041] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x4313a) [0x7f9c009d213a] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x399) [0x5653f17c2ae9] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 6: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f9c04a61890] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f9c009cde97] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f9c009cf801] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 9: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f9c00a18897] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f9c00a1f90a] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 11: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f9c00a26e1c] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 12: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x5653f1743b0a] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 13: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x5653f1745e72] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 14: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x5653f1729afb] zm_signal.cpp 104
2020-05-29 22:04:13 zms_e17 12132 ERR Backtrace 15: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f9c009b0b97] zm_signal.cpp 104
2020-05-29 22:04:13 web_php 1613 ERR Timed out waiting for msg /var/run/zm/zms-093748s.sock /usr/share/zoneminder/www/ajax/stream.php 93
2020-05-29 22:04:12 zms_e17 12132 ERR Got signal 6 (Aborted), crashing zm_signal.cpp 52
2020-05-29 22:04:12 zms_e17 12132 ERR Signal address is 0x2100002f64, from 0x7f9c009cde97 zm_signal.cpp 83
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5653f17c27c8] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f9c04a61890] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f9c009cde97] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f9c009cf801] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f9c00a18897] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f9c00a1f90a] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f9c00a26e1c] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x5653f1743b0a] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 8: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x5653f1745e72] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x5653f1729afb] zm_signal.cpp 104
2020-05-29 22:04:12 zms_e17 12132 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f9c009b0b97] zm_signal.cpp 104
2020-05-29 20:45:15 zms_e16 15311 ERR Unable to send raw frame 1: Broken pipe zm_eventstream.cpp 821
2020-05-29 20:44:58 web_php 1388 ERR Timed out waiting for msg /var/run/zm/zms-227755s.sock /usr/share/zoneminder/www/ajax/stream.php 93
2020-05-29 20:44:58 web_php 1388 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x4313a) [0x7f1e8ae6713a] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x399) [0x55caabff5ae9] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 6: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f1e8eef6890] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f1e8ae62e97] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f1e8ae64801] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 9: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f1e8aead897] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f1e8aeb490a] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 11: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f1e8aebbe1c] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 12: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x55caabf76b0a] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 13: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x55caabf78e72] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 14: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x55caabf5cafb] zm_signal.cpp 104
2020-05-29 20:44:57 zms_e9 15078 ERR Backtrace 15: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f1e8ae45b97] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Got signal 6 (Aborted), crashing zm_signal.cpp 52
2020-05-29 20:44:56 zms_e9 15078 ERR Signal address is 0x2100003ae6, from 0x7f1e8ae62e97 zm_signal.cpp 83
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55caabff57c8] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f1e8eef6890] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f1e8ae62e97] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f1e8ae64801] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f1e8aead897] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f1e8aeb490a] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f1e8aebbe1c] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x55caabf76b0a] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 8: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x55caabf78e72] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x55caabf5cafb] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f1e8ae45b97] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 11: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x55caabf5e59a] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2020-05-29 20:44:56 zms_e9 15078 ERR Signal address is 0x7f1e8fdf5038, from 0x7f1e8aebb98d zm_signal.cpp 83
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x3d) [0x7f1e8aebb98d] zm_signal.cpp 104
2020-05-29 20:44:56 zms_e9 15078 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(+0x43041) [0x7f1e8ae67041] zm_signal.cpp 104
2020-05-29 20:44:55 web_php 1386 ERR socket_sendto( /var/run/zm/zms-887691s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:55 web_js 1386 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-887691s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 20:44:54 web_php 1386 ERR Timed out waiting for msg /var/run/zm/zms-887691s.sock /usr/share/zoneminder/www/ajax/stream.php 93
2020-05-29 20:44:54 web_php 1386 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:54 web_js 1386 ERR getCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=event
2020-05-29 20:44:53 zms_e8 15032 ERR Signal address is 0x7fd672c51038, from 0x7fd66dd1798d zm_signal.cpp 83
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x558917acd7c8] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7fd671d52890] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x3d) [0x7fd66dd1798d] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(+0x43041) [0x7fd66dcc3041] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x4313a) [0x7fd66dcc313a] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x399) [0x558917acdae9] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 6: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7fd671d52890] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7fd66dcbee97] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7fd66dcc0801] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 9: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7fd66dd09897] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7fd66dd1090a] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 11: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7fd66dd17e1c] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 12: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x558917a4eb0a] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 13: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x558917a50e72] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 14: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x558917a34afb] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Backtrace 15: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fd66dca1b97] zm_signal.cpp 104
2020-05-29 20:44:53 zms_e8 15032 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 11: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x558917a3659a] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fd66dca1b97] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x558917a34afb] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 8: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x558917a50e72] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x558917a4eb0a] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7fd66dd17e1c] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7fd66dd1090a] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7fd66dd09897] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7fd66dcc0801] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7fd66dcbee97] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7fd671d52890] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x558917acd7c8] zm_signal.cpp 104
2020-05-29 20:44:52 zms_e8 15032 ERR Signal address is 0x2100003ab8, from 0x7fd66dcbee97 zm_signal.cpp 83
2020-05-29 20:44:52 zms_e8 15032 ERR Got signal 6 (Aborted), crashing zm_signal.cpp 52
2020-05-29 20:44:51 web_js 1613 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 20:44:51 web_php 1613 ERR socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:49 web_js 1613 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 20:44:48 web_php 1613 ERR socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:48 web_js 1613 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 20:44:45 web_js 1613 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event
2020-05-29 20:44:45 web_php 1613 ERR socket_sendto( /var/run/zm/zms-582903s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:43 web_js 1613 ERR getCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=event
2020-05-29 20:44:43 web_php 1613 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2192
2020-05-29 20:44:43 web_php 1613 ERR Timed out waiting for msg /var/run/zm/zms-582903s.sock /usr/share/zoneminder/www/ajax/stream.php 93
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 15: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f8e25fdeb97] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 14: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x55de173b5afb] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 13: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x55de173d1e72] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 12: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x55de173cfb0a] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 11: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f8e26054e1c] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f8e2604d90a] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 9: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f8e26046897] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f8e25ffd801] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f8e25ffbe97] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 6: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f8e2a08f890] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x399) [0x55de1744eae9] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x4313a) [0x7f8e2600013a] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(+0x43041) [0x7f8e26000041] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x3d) [0x7f8e2605498d] zm_signal.cpp 104
2020-05-29 20:44:42 zms_e7 14883 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f8e2a08f890] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55de1744e7c8] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Signal address is 0x7f8e2af8e038, from 0x7f8e2605498d zm_signal.cpp 83
2020-05-29 20:44:41 zms_e7 14883 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 11: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x55de173b759a] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f8e25fdeb97] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa7b) [0x55de173b5afb] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 8: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9runStreamEv+0x9c2) [0x55de173d1e72] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN11EventStream9sendFrameEi+0x4ba) [0x55de173cfb0a] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4cc) [0x7f8e26054e1c] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(+0x9090a) [0x7f8e2604d90a] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 4: /lib/x86_64-linux-gnu/libc.so.6(+0x89897) [0x7f8e26046897] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 3: /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f8e25ffd801] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f8e25ffbe97] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f8e2a08f890] zm_signal.cpp 104
2020-05-29 20:44:41 zms_e7 14883 ERR Signal address is 0x2100003a23, from 0x7f8e25ffbe97 zm_signal.cpp 83
2020-05-29 20:44:41 zms_e7 14883 ERR Got signal 6 (Aborted), crashing zm_signal.cpp 52
2020-05-29 20:44:40 zms_e7 14873 ERR Unable to send raw frame 5: Broken pipe zm_eventstream.cpp 821
2020-05-29 19:03:58 zmdc 1233 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2020-05-29 19:03:58 zma_m1 2648 ERR Shared data not initialised by capture daemon for monitor SV3Ccam zm_monitor.cpp 492
2020-05-29 19:01:42 zmdc 1233 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
What are all these errors in the log?
Re: What are all these errors in the log?
There was a problem that looked like this... but it has been fixed for a while now.
Exactly what version of ZM are you running? if on a debian/ubuntu based dist dpkg -s zoneminder will give the info.
apt-get dist-upgrade might also just upgrade you to the latest and fix the problem.
If you are going to live on the bleeding edge you will need to update to the latest version before we are able to help you. And keep up with what is going on in development. Otherwise stick to 1.34.
Package: zoneminder
Status: install ok installed
Priority: optional
Section: net
Installed-Size: 40684
Maintainer: Isaac Connor <isaac@zoneminder.com>
Architecture: amd64
Version: 1.35.4~20200515115321-bionic
Maybe this is why I can't playback recordings?
Priority: optional
Section: net
Architecture: amd64
20200515115321 is literally the date and time of the build. 2020-05-15 11:53:21. That was 2 weeks ago. Lots of fixes since then.
If you are going to run bleeding edge code you will want to update to the latest before posting a question/bug report, because the very first thing we are going to tell you to do is update.
So go update and see if your problem is fixed.
I'm new to Linux but I did:
also I did:
sudo apt upgrade zoneminder
and it still shows Version: 1.35.4~20200515115321-bionicsudo apt-get update
sudo apt upgrade
dpkg -s zoneminder
also I did:
Reading package lists... Done
Building dependency tree
Reading state information... Done
zoneminder is already the newest version (1.35.4~20200515115321-bionic).
Calculating upgrade... Done
The following packages have been kept back:
libavcodec-extra
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
As it happened, you were and are on the latest build, hence no change.
Look here: https://launchpad.net/~iconnor/+ppa-packages
My apologies, it appears that I havn't been triggering package builds. I just kicked one out, so when you have an update with june 1st in the version, you will be up to date, and I suspect it will fix your issue.
Thanks. It seems to work very well now. Videos do play back now and it seems to be recording. ZM has really come a long way since I last looked at it.
Here's the current error log produced even though it seems to work:
Date/Time
2020-06-01 20:49:31 zms_e47 4761 ERR Unable to send stream frame: Broken pipe zm_eventstream.cpp 836
2020-06-01 20:49:07 zms_e45 4695 ERR Unable to send stream frame: Broken pipe zm_eventstream.cpp 836
2020-06-01 20:33:28 zms_e19 1643 ERR Unable to send raw frame 43: Broken pipe zm_eventstream.cpp 819
2020-06-01 20:33:02 zms_e18 1337 ERR Unable to send raw frame 44: Broken pipe zm_eventstream.cpp 819
2020-06-01 20:32:23 zms_e17 1281 ERR Unable to send stream frame: Broken pipe zm_eventstream.cpp 836
2020-06-01 20:32:01 zms_e17 1230 ERR Unable to send raw frame 5: Broken pipe zm_eventstream.cpp 819
2020-06-01 20:32:00 zms_e18 1229 ERR Unable to send raw frame 4: Broken pipe zm_eventstream.cpp 819
2020-06-01 20:31:59 zms_e20 1227 ERR Unable to send raw frame 1: Broken pipe zm_eventstream.cpp 819
Just an FYI - hoping that any solution here on this broken pipe error will translate for same error I'm having with 1.34.15.
I'm seeing the same broken pipe errors in my logs, but I'm running 1.34.15. I get them every time I do do a playback (event). The operation does work/finish/complete, though it seems to always end up hanging a bit.
