Hi
I only have 139 events showing. But my /var/log/messages file has this message repeated
"zmaudit[3966]: INF [Deleted 10 log table entries by time]" around 50 lines of that every 30 minutes.
centos 7 current
any idea what is causing this?
Jim
messges about "deleted log table entries"
Re: messges about "deleted log table entries"
Hello again
I found a run_audit on the options page (3/4 down) and turned that off. That appears to have stopped the lines from being printed in the log file. I'll set up a cron.weekly later and see if that will run correctly.
I'd still like to know why it output so many lines each time (50+).
If run_audit from the command line a user then it produces 50+ lines, run sudo it produces 5.
Jim
Jim
Deleting a ton of lines takes forever and locks the table so that nothing can write to it. So we only delete a few lines at a time.
