[SOLVED] Getting monitor status from API
moasat
Post by moasat » Mon Feb 10, 2020 2:39 pm
I'm not sure this is a 1.34 issue but I did upgrade over the weekend. I'm writing an app and trying to get the monitor status through the API by calling /zm/api/monitors/alarm/id:5/command:status.json but the response I get back always has a blank status: {"status":""}. This is for every monitor. I've also tried forcing an alarm on the monitor but the status doesn't change. It shows up in the web GUI just fine. Maybe I have something configured wrong? I'm expecting to see one of Idle, Alert, Alarm, etc.
Re: Getting monitor status from API
Post by iconnor » Mon Feb 10, 2020 5:28 pm
I'm not so great with cakephp.... so I have no idea what the url actually means.
If you just do
/zm/api/monitors/5.json
you will get all the monitor data, including a Monitor_Status field.
moasat
Post by moasat » Mon Feb 10, 2020 6:02 pm
This is what I get from api/monitors/2.json. The Monitor_Status only shows "Connected", not one of Idle, Alarm, Alert. Also, I thought I read that Monitor_Status is not available in earlier versions of ZM and I was hoping to support those, although its not a requirement.
  "monitor": {
    "Monitor": {
      "Id": "2",
      "Name": "PTZ",
      "Notes": null,
      "ServerId": "0",
      "StorageId": "2",
      "Type": "Ffmpeg",
      "Function": "Modect",
      "Enabled": "1",
      "LinkedMonitors": "",
      "Triggers": "",
      "Device": "\/dev\/video0",
      "Channel": "0",
      "Format": "255",
      "V4LMultiBuffer": null,
      "V4LCapturesPerFrame": "1",
      "Protocol": "rtsp",
      "Method": "rtpRtsp",
      "Host": "user:password@ip-camera2",
      "Port": "554",
      "SubPath": "",
      "Path": "rtsp:\/\/user:password@ip-camera2\/live",
      "Options": null,
      "User": null,
      "Pass": null,
      "Width": "1920",
      "Height": "1080",
      "Colours": "4",
      "Palette": "0",
      "Orientation": "ROTATE_0",
      "Deinterlacing": "0",
      "DecoderHWAccelName": null,
      "DecoderHWAccelDevice": null,
      "SaveJPEGs": "3",
      "VideoWriter": "1",
      "OutputCodec": null,
      "OutputContainer": null,
      "EncoderParameters": "# Lines beginning with # are a comment \r\n# For changing quality, use the crf option\r\n# 1 is best, 51 is worst quality\r\n#crf=23",
      "RecordAudio": "0",
      "RTSPDescribe": false,
      "Brightness": "-1",
      "Contrast": "-1",
      "Hue": "-1",
      "Colour": "-1",
      "EventPrefix": "Event-",
      "LabelFormat": "%N - %d\/%m\/%y %H:%M:%S",
      "LabelX": "0",
      "LabelY": "0",
      "LabelSize": "1",
      "ImageBufferCount": "30",
      "WarmupCount": "2",
      "PreEventCount": "15",
      "PostEventCount": "15",
      "StreamReplayBuffer": "0",
      "AlarmFrameCount": "2",
      "SectionLength": "600",
      "MinSectionLength": "10",
      "FrameSkip": "0",
      "MotionFrameSkip": "0",
      "AnalysisFPSLimit": "5.00",
      "AnalysisUpdateDelay": "0",
      "MaxFPS": "30.000",
      "AlarmMaxFPS": "30.00",
      "FPSReportInterval": "100",
      "RefBlendPerc": "6",
      "AlarmRefBlendPerc": "6",
      "Controllable": "0",
      "ControlId": null,
      "ControlDevice": null,
      "ControlAddress": null,
      "AutoStopTimeout": null,
      "TrackMotion": "0",
      "TrackDelay": null,
      "ReturnLocation": "-1",
      "ReturnDelay": null,
      "DefaultRate": "100",
      "DefaultScale": "100",
      "DefaultCodec": "auto",
      "SignalCheckPoints": "10",
      "SignalCheckColour": "#0000c0",
      "WebColour": "red",
      "Exif": false,
      "Sequence": "2",
      "TotalEvents": "37",
      "TotalEventDiskSpace": "434525663",
      "HourEvents": "0",
      "HourEventDiskSpace": "0",
      "DayEvents": "1",
      "DayEventDiskSpace": "9388570",
      "WeekEvents": "5",
      "WeekEventDiskSpace": "50392474",
      "MonthEvents": "15",
      "MonthEventDiskSpace": "187283227",
      "ArchivedEvents": "0",
      "ArchivedEventDiskSpace": null,
      "ZoneCount": "1",
      "Refresh": null
    "Monitor_Status": {
      "MonitorId": "2",
      "Status": "Connected",
      "CaptureFPS": "14.29",
      "AnalysisFPS": "5.26",
      "CaptureBandwidth": "154519"
asker
Post by asker » Tue Feb 11, 2020 4:36 pm
If you want alarm status then
https://server/api/monitors/alarm/id:X/command:status.json
is correct. I just checked on my monitors and I am correctly getting the right status value based on the alarmed status. I also forced an alarm on a modect monitor, and the status switch correctly from 0 to 2.
Please don't ask me questions via PM. Feel free to post in the forums or Github
moasat
Post by moasat » Wed Feb 12, 2020 1:29 am
Hmm, mine is always blank. I have 5 different monitors, all return {"status":""} regardless of the status. Maybe a regression bug in 1.34?
Post by iconnor » Wed Feb 12, 2020 2:50 pm
I have two thoughts on this:
#1 if this was a multi-server setup and we asked a server that wasn't the recording server, it would fail.
#2 If auth not working, perhaps due to timezone problem, then maybe we get nothing.
The thing to do would be turn on debugging and see what zmu is saying.
moasat
Post by moasat » Thu Feb 13, 2020 12:43 am
Its a single server setup. And all of the previous calls are working. But zmu.log is giving an error of:
02/12/20 18:37:58.035870 zmu[27091].ERR-zmu.cpp/435 [Username must be supplied]
I'm using token based auth, so the URLs look like this:
https://zm:443/zm/api/monitors/alarm/id:2/command:status.json?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTgxNTUwNTc3LCJleHAiOjE1ODE1NTc3NzcsInVzZXIiOiJhZG1pbiIsInR5cGUiOiJhY2Nlc3MifQ.4X2kXbEuqq-uo9N6kj4sJ5NdJFpDFjaqLlt9xVlRmnk
I tried changing the url to https://user@zm and also https://user:pass@zm but neither made a difference. What username should I be using here? Again, all the other API calls I'm using seem to be working ok. I also tried adding user as a query param and also user and pass as query params. Still no difference.
asker
Post by asker » Thu Feb 13, 2020 1:28 am
Try setting AUTH_RELAY to hashed.
moasat
Post by moasat » Fri Feb 14, 2020 2:59 am
Setting AUTH_RELAY to Hashed fixed it. It looks like that change had no other adverse effects so I'll keep it. Any explanation why everything else was working but that wasn't?
