davama
Post
by davama » Tue Oct 15, 2019 4:28 pm
First time poster on this forum.
Attempting to follow the redhat guide
https://zoneminder.readthedocs.io/en/la ... edhat.html
But want to use nginx instead of apache.
[root@video ~]# cat /etc/redhat-release
CentOS Linux release 7.7.1908 (Core)
[root@video ~]# uname -a
Linux video 3.10.0-1062.1.2.el7.x86_64 #1 SMP Mon Sep 30 14:19:46 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@video ~]# zmc -v
1.32.3
When trying to install zoneminder-nginx I get the following conflicts:
[root@video ~]# yum install zoneminder-nginx
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.atlanticmetro.net
* epel: fedora-epel.mirrors.tds.net
* extras: mirror.atlanticmetro.net
* rpmfusion-free-updates: mirror.math.princeton.edu
* updates: mirror.atlanticmetro.net
Resolving Dependencies
--> Running transaction check
---> Package zoneminder-nginx.x86_64 0:1.32.3-1.el7 will be installed
--> Processing Conflict: zoneminder-httpd-1.32.3-1.el7.x86_64 conflicts zoneminder-nginx
--> Processing Conflict: zoneminder-nginx-1.32.3-1.el7.x86_64 conflicts zoneminder-httpd
--> Finished Dependency Resolution
Error: zoneminder-nginx conflicts with zoneminder-httpd-1.32.3-1.el7.x86_64
Error: zoneminder-httpd conflicts with zoneminder-nginx-1.32.3-1.el7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
I did try installing zoneminder withouth zoneminder-httpd but zoneminder depends on httpd
[root@video ~]# yum install zoneminder --exclude="zoneminder-httpd"
* base: mirror.siena.edu
* extras: mirror.siena.edu
* updates: mirror.siena.edu
---> Package zoneminder.x86_64 0:1.32.3-1.el7 will be installed
--> Processing Dependency: zoneminder-httpd(x86-64) = 1.32.3-1.el7 for package: zoneminder-1.32.3-1.el7.x86_64
Error: Package: zoneminder-1.32.3-1.el7.x86_64 (rpmfusion-free-updates)
Requires: zoneminder-httpd(x86-64) = 1.32.3-1.el7
Wondering how I can go about this without breakage?
Any input is much appreciated!
Thank you,
Dave
davama on Wed Oct 16, 2019 2:12 pm, edited 1 time in total.
kitkat
Post
by kitkat » Tue Oct 15, 2019 7:36 pm
davama wrote: ↑Tue Oct 15, 2019 4:28 pm
1.32.3
You'll probably have to remove the old version before installing the new one...
davama
Post
by davama » Tue Oct 15, 2019 8:29 pm
Thank you for the reply @kitkat
kitkat wrote: ↑Tue Oct 15, 2019 7:36 pm
Unfortunately I do not understand what you mean by that. You men 1.33.x? I believe this is still in development, not for public release.
I am using, as the doc says, rpmfusion repo which has the 1.32.x release.
https://download1.rpmfusion.org/free/el ... /x86_64/z/
For some reason zoneminder-1.32.3-1.el7.x86_64.rpm depends on zoneminder-httpd-1.32.3-1.el7.x86_64.rpm and you cannot install zoneminder-nginx-1.32.3-1.el7.x86_64.rpm without receiving the "yum conflict error" on POST#1
Is this by design or am I doing something wrong?
Personally does not make sense the dependency, since the packages are separated but I am a first time user of this software, so probably i'm wrong.
Any more input is much appreciated!
kitkat
Post
by kitkat » Tue Oct 15, 2019 9:05 pm
I may be misreading all this but, as you have zmc installed I'm presuming that you also have some version of zoneminder already installed, probably the -httpd version (that's what I ended up with without specifying a version), and that the conflict message therefore relates to the -nginx version conflicting with the already-installed version.
'yum autoremove zoneminder' should remove the installed version along with all of its otherwise-unused dependencies and allow the -nginx version to be installed instead.
e2a: Maybe 'yum autoremove zoneminder-httpd' would suffice?
davama
Post
by davama » Wed Oct 16, 2019 12:33 pm
This is a new install so there is no previous version.
[root@video ~]# yum remove zoneminder-httpd
---> Package zoneminder-httpd.x86_64 0:1.32.3-1.el7 will be erased
---> Package zoneminder.x86_64 0:1.32.3-1.el7 will be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
zoneminder-httpd x86_64 1.32.3-1.el7 @rpmfusion-free-updates 7.0 k
Removing for dependencies:
zoneminder x86_64 1.32.3-1.el7 @rpmfusion-free-updates 0.0
Transaction Summary
Remove 1 Package (+1 Dependent package)
Installed size: 7.0 k
Is this ok [y/N]:
Problem is that I CANNOT install -nginx package without yum complaining of conflict. zoneminder depends on -httpd, why? it should be the other way around. -httpd or -nginx should depend on zoneminder.
[root@video ~]# yum deplist zoneminder
package: zoneminder.x86_64 1.32.3-1.el7
dependency: /bin/sh
provider: bash.x86_64 4.2.46-33.el7
dependency: zoneminder-common(x86-64) = 1.32.3-1.el7
provider: zoneminder-common.x86_64 1.32.3-1.el7
dependency: zoneminder-httpd(x86-64) = 1.32.3-1.el7
provider: zoneminder-httpd.x86_64 1.32.3-1.el7
[root@video ~]# yum deplist zoneminder-httpd
package: zoneminder-httpd.x86_64 1.32.3-1.el7
dependency: /bin/sh
dependency: httpd
provider: httpd.x86_64 2.4.6-90.el7.centos
dependency: php
provider: php.x86_64 5.4.16-46.el7
[root@video ~]# yum deplist zoneminder-nginx
package: zoneminder-nginx.x86_64 1.32.3-1.el7
dependency: /bin/sh
dependency: fcgiwrap
provider: fcgiwrap.x86_64 1.1.0-9.20181108git99c942c.el7
dependency: nginx
provider: nginx.x86_64 1:1.12.2-3.el7
dependency: php-fpm
provider: php-fpm.x86_64 5.4.16-46.el7
To summarize, one cannot install -nginx package because it will conflict with -httpd package.
kitkat
Post
by kitkat » Wed Oct 16, 2019 1:14 pm
davama wrote: ↑Wed Oct 16, 2019 12:33 pm
So where did your copy of zmc in the first post come from?
dependency: /bin/sh
dependency: /bin/sh
dependency: httpd
dependency: php
dependency: /bin/sh
dependency: nginx
dependency: php-fpm
It looks like installing zoneminer without specifying either -httpd or -nginx defaults to the -httpd version, which then obviously depends on zoneminder-httpd, and it also pulls in -common.
The -nginx install also includes -common, along with the other nginx-specific files, but it doesn't include -httpd.
So what happens if you skip the 'install zoneminder' step completely and go straight to 'install zoneinder-nginx'? I guess you may need to 'yum autoremove zoneminder' first, but yum may be smart enough to figure things out.
e2a: Reading again, I'm kind of surprised that 'yum install zoneminder-nginx' doesn't work now that zoneminder-httpd and zoneminder have been removed because there should no longer be any conflicts.
kitkat
Post
by kitkat » Wed Oct 16, 2019 1:37 pm
This is from a system that has an older version of ZM (1.32.2), so none of the -common, -hhtpd, or -nginx packages are installed but most of the other dependencies from zoneminder-common are, and it looks like it'd work OK...
$ yum install zoneminder-nginx
epel/x86_64/metalink | 28 kB 00:00:00
* base: mirror.as29550.net
* epel: mirror.kinamo.be
* extras: mirror.as29550.net
* rpmfusion-free-updates: mirror.ehv.weppel.nl
* rpmfusion-nonfree-updates: mirror.ehv.weppel.nl
* updates: mirror.sov.uk.goscomb.net
base | 3.6 kB 00:00:00
epel | 5.3 kB 00:00:00
extras | 2.9 kB 00:00:00
rpmfusion-free-updates | 3.7 kB 00:00:00
rpmfusion-nonfree-updates | 3.7 kB 00:00:00
updates | 2.9 kB 00:00:00
(1/4): rpmfusion-nonfree-updates/x86_64/group_gz | 920 B 00:00:00
(2/4): rpmfusion-free-updates/x86_64/group_gz | 1.4 kB 00:00:00
(3/4): epel/x86_64/updateinfo | 1.0 MB 00:00:00
(4/4): epel/x86_64/primary_db | 6.9 MB 00:00:01
--> Processing Dependency: zoneminder-common(x86-64) = 1.32.3-1.el7 for package: zoneminder-nginx-1.32.3-1.el7.x86_64
--> Processing Dependency: php-fpm for package: zoneminder-nginx-1.32.3-1.el7.x86_64
--> Processing Dependency: nginx for package: zoneminder-nginx-1.32.3-1.el7.x86_64
--> Processing Dependency: fcgiwrap for package: zoneminder-nginx-1.32.3-1.el7.x86_64
---> Package fcgiwrap.x86_64 0:1.1.0-9.20181108git99c942c.el7 will be installed
--> Processing Dependency: libfcgi.so.0()(64bit) for package: fcgiwrap-1.1.0-9.20181108git99c942c.el7.x86_64
---> Package nginx.x86_64 1:1.12.2-3.el7 will be installed
--> Processing Dependency: nginx-all-modules = 1:1.12.2-3.el7 for package: 1:nginx-1.12.2-3.el7.x86_64
--> Processing Dependency: nginx-filesystem = 1:1.12.2-3.el7 for package: 1:nginx-1.12.2-3.el7.x86_64
--> Processing Dependency: nginx-filesystem for package: 1:nginx-1.12.2-3.el7.x86_64
--> Processing Dependency: libprofiler.so.0()(64bit) for package: 1:nginx-1.12.2-3.el7.x86_64
---> Package php-fpm.x86_64 0:5.4.16-46.el7 will be installed
---> Package zoneminder-common.x86_64 0:1.32.3-1.el7 will be installed
---> Package fcgi.x86_64 0:2.4.0-25.el7 will be installed
---> Package gperftools-libs.x86_64 0:2.6.1-1.el7 will be installed
---> Package nginx-all-modules.noarch 1:1.12.2-3.el7 will be installed
--> Processing Dependency: nginx-mod-http-geoip = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
--> Processing Dependency: nginx-mod-http-image-filter = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
--> Processing Dependency: nginx-mod-http-perl = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
--> Processing Dependency: nginx-mod-http-xslt-filter = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
--> Processing Dependency: nginx-mod-mail = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
--> Processing Dependency: nginx-mod-stream = 1:1.12.2-3.el7 for package: 1:nginx-all-modules-1.12.2-3.el7.noarch
---> Package nginx-filesystem.noarch 1:1.12.2-3.el7 will be installed
---> Package nginx-mod-http-geoip.x86_64 1:1.12.2-3.el7 will be installed
---> Package nginx-mod-http-image-filter.x86_64 1:1.12.2-3.el7 will be installed
--> Processing Dependency: gd for package: 1:nginx-mod-http-image-filter-1.12.2-3.el7.x86_64
--> Processing Dependency: libgd.so.2()(64bit) for package: 1:nginx-mod-http-image-filter-1.12.2-3.el7.x86_64
---> Package nginx-mod-http-perl.x86_64 1:1.12.2-3.el7 will be installed
---> Package nginx-mod-http-xslt-filter.x86_64 1:1.12.2-3.el7 will be installed
---> Package nginx-mod-mail.x86_64 1:1.12.2-3.el7 will be installed
---> Package nginx-mod-stream.x86_64 1:1.12.2-3.el7 will be installed
---> Package gd.x86_64 0:2.0.35-26.el7 will be installed
Installing:
zoneminder-nginx x86_64 1.32.3-1.el7 rpmfusion-free-updates 21 k
Installing for dependencies:
fcgi x86_64 2.4.0-25.el7 epel 47 k
fcgiwrap x86_64 1.1.0-9.20181108git99c942c.el7 epel 21 k
gd x86_64 2.0.35-26.el7 base 146 k
gperftools-libs x86_64 2.6.1-1.el7 base 272 k
nginx x86_64 1:1.12.2-3.el7 epel 531 k
nginx-all-modules noarch 1:1.12.2-3.el7 epel 16 k
nginx-filesystem noarch 1:1.12.2-3.el7 epel 17 k
nginx-mod-http-geoip x86_64 1:1.12.2-3.el7 epel 23 k
nginx-mod-http-image-filter x86_64 1:1.12.2-3.el7 epel 27 k
nginx-mod-http-perl x86_64 1:1.12.2-3.el7 epel 36 k
nginx-mod-http-xslt-filter x86_64 1:1.12.2-3.el7 epel 26 k
nginx-mod-mail x86_64 1:1.12.2-3.el7 epel 54 k
nginx-mod-stream x86_64 1:1.12.2-3.el7 epel 76 k
php-fpm x86_64 5.4.16-46.el7 base 1.4 M
zoneminder-common x86_64 1.32.3-1.el7 rpmfusion-free-updates 8.7 M
Transaction Summary
Install 1 Package (+15 Dependent packages)
Total download size: 11 M
Installed size: 45 M
Is this ok [y/d/N]:
kitkat on Wed Oct 16, 2019 1:40 pm, edited 1 time in total.
davama
Post
by davama » Wed Oct 16, 2019 1:39 pm
kitkat wrote: ↑Wed Oct 16, 2019 1:14 pm
Because I installed zoneminder in the first place, so for community support purposes, I was simply showing which version of zoneminder I am having an issue with....
Nothing will happen, as already posted:
dependency: /bin/sh
dependency: nginx
dependency: php-fpm
Here is the proof:
[root@video ~]# rpm -qa "zone*"
zoneminder-common-1.32.3-1.el7.x86_64
[root@video ~]#
Installing:
Transaction Summary
Install 1 Package (+10 Dependent packages)
Total download size: 2.4 M
Installed size: 6.9 M
Is this ok [y/d/N]: n
kitkat
Post
by kitkat » Wed Oct 16, 2019 1:45 pm
davama wrote: ↑Wed Oct 16, 2019 1:39 pm
Here is the proof:
[root@video ~]#
Installing:
Transaction Summary
Isn't that right, though? No conflicts, zoneminder-common already installed, zoneminder-nginx and its dependencies to be installed, with no mention of zoneminder-httpd.
davama
Post
by davama » Wed Oct 16, 2019 1:55 pm
kitkat wrote: ↑Wed Oct 16, 2019 1:45 pm
Not to me, but I am a first time user of this software, so idk. I am trying to provide a POC.
Either way, it does not make sense that `zoneminder` cannot be installed along with `-nginx`
[root@video ~]#
---> Package zoneminder-httpd.x86_64 0:1.32.3-1.el7 will be installed
kitkat
Post
by kitkat » Wed Oct 16, 2019 2:01 pm
davama wrote: ↑Wed Oct 16, 2019 1:55 pm
[root@video ~]#
You're all done - There's no need to install zoneminder when either zoneminder-httpd or zoneminder-nginx are installed.
The 'zoneminder' package is effectively the same as/a shortcut to 'zoneminder-httpd'
e2a: Basically, you should install just one of zoneminder-httpd, zoneminder-nginx, or zoneminder (which, as mentioned, is the same as zoneminder-httpd). zoneminder-common will be installed as a dependency in all cases.
davama
Post
by davama » Wed Oct 16, 2019 2:12 pm
No way??
That is very different from what i've seen with other applications (separation from actual application and frontend preference)
[root@video ~]# yum search zoneminder
zoneminder-common.x86_64 : Common files for ZoneMinder, not tied to a specific web server
zoneminder-httpd.x86_64 : ZoneMinder configuration for Apache web server
zoneminder-nginx.x86_64 : ZoneMinder configuration for Nginx web server
mythzoneminder.x86_64 : A module for MythTV for camera security and surveillance
zoneminder.x86_64 : A camera monitoring and analysis tool
Interesting...
I'll give it a go.
Thank you very much for your help and patience @kitkat
Marking as solved
kitkat
Post
by kitkat » Wed Oct 16, 2019 2:20 pm
I'm pretty sure that's the way it works.
I suspect that you may still run into problems though, because you'll now probably have both Apache and nginx installed, and they may not play nicely together (or they may, I really don't know).
I would have done a 'yum autoremove zoneminder-httpd' to remove it as well as all its otherwise-unused dependencies.
I'd be tempted to autoremove zm-nginx, install zm-httpd again, autoremove that, and then reinstall zm-nginx.
Users browsing this forum: No registered users and 5 guests
