Im suddently after an server reboot, starting to see quite poor performance, on primarily on one of two webcams.
I have many of these errors in the log:
Any clues, why this happened? As stated, it came "out of the blue", after an server reboot.
DATE/TIME
COMPONENT SERVER PID LEVEL MESSAGE FILE LINE
2019-05-13 13:22:04.608830 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:22:04.583234 zmc_m18 2820 FAT Unable to decode frame at frame 224 zm_ffmpeg_camera.cpp 178
2019-05-13 13:21:32.131500 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:21:32.107847 zmc_m18 2776 FAT Unable to decode frame at frame 2425 zm_ffmpeg_camera.cpp 178
2019-05-13 13:18:55.438130 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:18:55.414539 zmc_m18 2737 FAT Unable to decode frame at frame 1387 zm_ffmpeg_camera.cpp 178
2019-05-13 13:18:48.453139 web_php 1426 ERR Socket /var/run/zm/zms-000632s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2033
2019-05-13 13:18:48.191450 web_php 772 ERR Socket /var/run/zm/zms-285838s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2033
2019-05-13 13:18:47.110820 web_js 770 ERR TypeError: undefined is not an object (evaluating 'type.indexOf') https://zm.mork.xyz/zm/tools/mootools/mootools-core.js 1485
2019-05-13 13:16:58.449830 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:16:58.416992 zmc_m18 2688 FAT Unable to decode frame at frame 2090 zm_ffmpeg_camera.cpp 178
2019-05-13 13:14:13.817520 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:14:13.792584 zmc_m18 2589 FAT Unable to decode frame at frame 4993 zm_ffmpeg_camera.cpp 178
2019-05-13 13:09:36.171830 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 13:09:36.141558 zmc_m18 2329 FAT Unable to decode frame at frame 11563 zm_ffmpeg_camera.cpp 178
2019-05-13 12:57:12.784570 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:57:12.758686 zmc_m18 2292 FAT Unable to decode frame at frame 1290 zm_ffmpeg_camera.cpp 178
2019-05-13 12:55:24.359800 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:55:24.335360 zmc_m18 2288 FAT Unable to decode frame at frame 420 zm_ffmpeg_camera.cpp 178
2019-05-13 12:54:31.723430 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:54:31.695367 zmc_m18 2240 FAT Unable to decode frame at frame 1693 zm_ffmpeg_camera.cpp 178
2019-05-13 12:51:57.401260 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:51:57.374961 zmc_m18 2155 FAT Unable to decode frame at frame 3469 zm_ffmpeg_camera.cpp 178
2019-05-13 12:47:29.216560 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:47:29.185294 zmc_m18 2108 FAT Unable to decode frame at frame 1574 zm_ffmpeg_camera.cpp 178
2019-05-13 12:45:20.075590 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:45:20.047956 zmc_m18 2103 FAT Unable to decode frame at frame 426 zm_ffmpeg_camera.cpp 178
2019-05-13 12:44:35.132550 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:44:35.104798 zmc_m18 2077 FAT Unable to decode frame at frame 359 zm_ffmpeg_camera.cpp 178
2019-05-13 12:43:58.200440 zmdc 776 ERR 'zmc -m 18' exited abnormally, exit status 255 zmdc.pl
2019-05-13 12:43:58.176168 zmc_m18 2048 FAT Unable to decode frame at frame 1120 zm_ffmpeg_camera.cpp 178
So, it seems that ZM "drains" much of the network, or performance itself from the camera ?
E.g.
zoneminder started
ping 192.168.10.73 -c 10
PING 192.168.10.73 (192.168.10.73) 56(84) bytes of data.
64 bytes from 192.168.10.73: icmp_seq=1 ttl=64 time=103 ms
64 bytes from 192.168.10.73: icmp_seq=2 ttl=64 time=441 ms
64 bytes from 192.168.10.73: icmp_seq=3 ttl=64 time=167 ms
64 bytes from 192.168.10.73: icmp_seq=4 ttl=64 time=792 ms
64 bytes from 192.168.10.73: icmp_seq=6 ttl=64 time=86.7 ms
64 bytes from 192.168.10.73: icmp_seq=7 ttl=64 time=860 ms
64 bytes from 192.168.10.73: icmp_seq=8 ttl=64 time=883 ms
64 bytes from 192.168.10.73: icmp_seq=9 ttl=64 time=906 ms
64 bytes from 192.168.10.73: icmp_seq=10 ttl=64 time=930 ms
--- 192.168.10.73 ping statistics ---
10 packets transmitted, 9 received, 10% packet loss, time 9010ms
rtt min/avg/max/mdev = 86.704/574.837/930.845/350.395 ms
64 bytes from 192.168.10.73: icmp_seq=1 ttl=64 time=0.567 ms
64 bytes from 192.168.10.73: icmp_seq=2 ttl=64 time=0.803 ms
64 bytes from 192.168.10.73: icmp_seq=3 ttl=64 time=348 ms
64 bytes from 192.168.10.73: icmp_seq=4 ttl=64 time=371 ms
64 bytes from 192.168.10.73: icmp_seq=5 ttl=64 time=0.583 ms
64 bytes from 192.168.10.73: icmp_seq=6 ttl=64 time=0.701 ms
64 bytes from 192.168.10.73: icmp_seq=7 ttl=64 time=0.523 ms
64 bytes from 192.168.10.73: icmp_seq=8 ttl=64 time=0.735 ms
64 bytes from 192.168.10.73: icmp_seq=9 ttl=64 time=0.554 ms
64 bytes from 192.168.10.73: icmp_seq=10 ttl=64 time=0.805 ms
10 packets transmitted, 10 received, 0% packet loss, time 9141ms
rtt min/avg/max/mdev = 0.523/72.590/371.892/143.955 ms
